Old 07-08-2013, 02:02 PM
Senior ClubCobra Member
Default What have I got?? Need some help identifying my potential project
Original post of this thread by Robbycoo was deleted, throwing the sequence of replies out of whack.
Here is a replica of the original post:
Hi All
My first post failed im afraid, however, ive stumbled across an old cobra project that has not moved in literally 10-15 years! The current owner is more into motorbikes and has no interest in completing this car any longer. However, I now have some space and enthusiasm! The current owner doesn't know too much about the kit and before I offer to take off his hands I need to understand what I have got. Can anyone from here help??
Kind Regards and Thanks!
Link to Images:
Robert_James_Cooney's Library | Photobucket
Library Slideshow by Robert_James_Cooney | Photobucket
Old 07-08-2013, 02:32 PM
mickmate's Avatar
Hi Rob, if you get some pictures that would be the only way to go. Get some of the frame, front and rear suspension, body, dash, cowl areas and any others are a bonus. We love identifying kits on here and there's some very knowledgeable folks here to help. As suggested photo bucket, FB, Image shack or something to host pics, you can also put some in your album on here.
mickmate
http://www.actoncustom.com/
Old 07-08-2013, 02:37 PM
Default Link to Images attached!
Thanks for advice.
PLease find attached link to images
or slide show
Regards
Rob
Old 07-08-2013, 02:40 PM
Hi and thanks!! I have added the pics via photobucket! This might present a challenge!
Rob
Old 07-08-2013, 03:01 PM
Hi All
Link to Images:
Old 07-08-2013, 06:43 PM
decooney's Avatar
From one Cooney to another, what is the wheelbase measurement from the center cap of the front wheel to the center cap on the rear wheel?
Maybe my brain is stretched after a long day at work, but that car looks a bit longer than 90" center to center in the photo.
Duane
Old 07-08-2013, 07:15 PM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
An old Everett-Morrison maybe? The gel coat looks dark green in the pics - is that just the lighting?
Pete
Old 07-08-2013, 07:51 PM
Here is a link to a UK Cobra Club. They might be able to help also if not a bit better.
UK Cobra Club - The Front Page
Terry
Old 07-09-2013, 05:45 PM
REAL 1's Avatar
Banned
Wheelbase is too long for an EM.
What Brit replica companies make an extended wheelbase chasiss?
Old 07-09-2013, 07:16 PM
PSB's Avatar
PSB PSB is offline
EM made a 96" wheelbase chassis. I sat in one in their factory in FL.
Pete
Old 07-09-2013, 07:32 PM
Ls6venom's Avatar
Cobra Make, Engine: Everett-Morrison, Pushrod 16 valve V-8, Aluminum block/heads, GM engine-control system with port fuel injection
Send a message via AIM to Ls6venom
EM didn't use an torsion bar style front end that I am aware of.
55 mph is unsafe.. its fast enough to kill you, but slow enough to make you think your safe...
Old 07-09-2013, 08:51 PM
decooney's Avatar
robbycoo chassis vs. early Everett Morrison chassis for comparison purposes. Quite different.
Early EM Chassis:
robbycoo chassis:
Duane
Old 07-10-2013, 06:34 AM
Thanks Guys, Those big tubular longitudinals are very similar to the EM and different to a number of other Chassis I have seen on more common models in the UK. I have compared with Chassis from Dax, AK, Pilgrim and Gardener Douglas but its quite different. That said the EM is the closest I have seen so far!
Mine seems to have a hole for a centrally mounted tank filler (not sure whether this is another clue). Also by my reckoning, this kit could be from around early 90s!?
Youve promted my interest whats the difference between the 90" and the 96" wheelbase? are these the main two sizes for cobra's
Best
Rob
Old 07-10-2013, 07:19 AM
decooney's Avatar
Rob,
Knowing the wheelbase measurement helps to narrow down the manufacturers as many were 90", while others offered the stretched layout in 95/96". A buddy of mine had on old King Cobra stretched version with all Corvette running gear and parts as an example. You look for unique signature items about the design to help narrow it down.
Another thing I noticed about your chassis is how WIDE the side rocker tubes are pushed out towards the tires. On some cars you can see these tubes hanging underneath with the body mounted which is another clue. Not only does your car look longer than 90", it makes me wonder if the body is wider than a normal Cobra too. It's hard to tell with photos until you park it next to another 90" wheelbase Cobra to see the proportions. You could measure the wheelbase length and how wide the track is from center-to-center on the front wheels too. Its hard to see from the photos if they are normal aspect ratio or wider than normal.
Can you post a picture of the seats and bits that came with the car too?
Duane
Old 07-10-2013, 07:46 PM
REAL 1's Avatar
Banned
Pete
Wasn't aware of that.
Tags
challenge, identification, identify, quiz, what is it
