November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-19-2013, 07:30 PM
Default Burns from exhaust
I recently looked at a car that appeared to have had blistered paint above the exhuast
Seemed to be between the vents and the exhaust outlets. Is this common or is there something wrong here.
I looked like nice cooked paint, with blisters.
Old 07-19-2013, 10:35 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
It is unusual and there is an issue. It could be as simple as a missing heat shield or the results of something worse.
Old 07-20-2013, 07:04 AM
mdross1's Avatar
Wonder about clearance next thought would be motor mounts not up to snuff
Old 07-20-2013, 02:44 PM
The damage appeared to be directly above the collector, right where it exits the fiberglass. It was straight up from the exhaust, not blowing back, so I am assuming maybe it occurred while not moving? Looked like radiant heat damage to me.
Paint was kinda brownish tinted.
Old 07-20-2013, 03:38 PM
Could have been messing around and running without the side pipes. Maybe at the races?
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 07-20-2013, 10:33 PM
lamaluv's Avatar
My car has the exact blistered paint and it was caused by a shop forgetting to turn on the large floor fans while the car was being run on a chassis dyno.
Old 07-21-2013, 02:32 AM
Jamo's Avatar
Super Moderator
I don't have blistered paint above the pipes.
Jamo
Old 07-21-2013, 08:01 AM
Cobra Make, Engine: Scratch-built 427 MR
I had a problem of blistering paint on a Cobra about 25 years ago, in the same area. I had used a lacquer based filler instead of bondo and the lacquer obviously hadn't cured. Heat from the exhaust caused the filler to blister. Ground the area back to the fiberglass, filled with bondo, problem solved. Fortunately, the paint wasn't metallic.
Old 07-21-2013, 08:27 AM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
You may have blistering under the "censored" sticker on your avatar.
Dave
Old 07-21-2013, 11:00 AM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
A friend had that happen when he was first starting up his car. Primary reason he gave: engine running way too lean at first and his not paying attention to all the excess heat.
Old 07-21-2013, 12:05 PM
How far was his exhaust from the body? Some of the ones that I have seen were only 1/4" or closer. Mine were over 1/2" maybe even closter to 3/4". Does not look as good to have that big gap. But I did not worry about the paint burning or blistering.
This is not just on fiberglass cars either. Painted metal cars can/will have the same issue.
Terry
