Old 09-05-2013, 01:32 PM
mtrain2000's Avatar
Cobra Make, Engine: Shell Valley
Default Factory Five coupe question......
I recently bought an 02 Shell Valley 427 Cobra, and I was thinking about the future, and building a FF Daytona Coupe as that has always been my dream car [Well under the GT40, but I don't see ever having the $$$ for that deal].
Anyway, I looked on the FF website, and this is what they list for the base model kit.
Here’s a list of what comes standard in the Factory Five Racing Type 65 Coupe, Base Kit.
Frame:
Complete jig-welded original style 4” round tube frame. 95” wheelbase chassis. Includes all mounts ready to accept small block Ford 302 and 351 engines and Ford running gear from 1987-1993 Mustangs.
• Includes full roll cage and SCCA style rear crossbar in cockpit
Body:
Hand laid 3/16” laminate composite body includes hinged nose, main rear clip and doors with hinged glass rear window. Made with high quality vinylester resin.
• Driver and Passenger doors with molded door liners and DOT door latches
• Front nose with hinge kit. Includes gas strut supports, fasteners, and under nose body mount supports
• Original style molded-in hood scoop and fog light recesses
• Rear main body section comes with separate rivet-on rear spoiler
• Original style scoops and footbox vents
• Includes secondary body fasteners
• Adhesive backed foam weatherstrip
• Body mount fasteners
• Engine bay and rear trunk area seal, push on rubber bulb seal
• Rubber hood and hatch bumpers
• Includes adjustable door hinges, latches and fasteners
• Includes an opening vintage rear glass window with hinge, struts, and vintage latch with fasteners.
• Includes glass front windshield (DOT safety glass – windshield and hatch)
• Includes side window, air scoops, and framed sliding side windows
Chassis Aluminum Panels:
Includes over 20 precision CNC cut, pre-formed 6061-T6 aluminum panels for cockpit (floors, trans cover, and footboxes), rear trunk area, and engine bay/firewall/splash guards.
• 1200 pre-packaged rivets 1/8” and 3/16” short & long
• Complete cockpit aluminum with pre-formed footboxes, floors and transmission tunnel. Includes speedo cable block-off plate and trans harness block-off plates. Also includes aluminum dash with cut-outs
• Engine bay aluminum assembly with aluminum radiator duct surrounds and splash guards
• Complete aluminum trunk area
Front Suspension:
Includes high quality Koni™ brand mono_tube, rod-end, coil-over shocks, adjustable tubular upper a-arms with ball joints, adapter brackets and all grade-8 mounting hardware. Front suspension come ready to use Mustang lower control arm/spindle and brakes.
• Koni™ brand high performance mono-tube, rod-end shock absorbers
• Adjustable upper control arms with ball joints and fasteners
• Grade-8 mounting hardware
Rear Suspension:
Type 65 Coupe base kit includes rear axle brackets, fasteners and axle straps to mount your Mustang 8.8” rear solid axle and brakes. Comes with all fasteners and hardware required to install.
Brake/Fuel Lines:
Base kit comes with pre-flared brake/fuel lines, (3/16”, 1/4″ and 5/16”) and fasteners to use OEM style fuel tank and system. Includes polished vintage Aston LeMans flip top gas cap, integral modern fuel pressure cap and adaptor kit, fuel lines, connectors, filler neck and fasteners.
• Pre-flared fuel lines (1/4” and 5/16”) with unions, barbs, hose clamps and high press flex lines and fasteners
• Aston LeMans original polished aluminum fuel cap with integral pressure cap, gaskets, ground strap, fuel hose to tank with fasteners
Steering Kit:
Steering adapter kit to utilize Mustang steering rack includes upper shaft, pillow blocks, flange bearings, fasteners, lower shaft and u-joints. Features a collapsible column, Vintage wood and aluminum steering wheel with aluminum boss, center section and Factory Five Racing badge.
• Lower steering shaft with ’87-93 rack adapter (3/4”-36” spline)
• Upper steering shaft, spring washer and fasteners
• 14” Vintage wood and aluminum steering wheel with boss and FFR center section and fasteners
• Steering bearings and hardware, including flange bearing, pillow block bearing and fasteners
Complete Cooling System/Parts:
Electric cooling fan, thermostat, relays and mounting kit with hardware. Cooling system also includes stainless steel hoses, and all necessary fasteners.
• Electric cooling fan, high flow 16” puller, with mounting kit and connectors
• Aluminum radiator, in-line filler neck and pressure cap
• Radiator mount kit and fasteners
• Stainless Steel radiator hose kit incl. adapter kit, fasteners and hose
• Overflow tank with cap, hoses, hose clamps and mounting hardware
• 185 degree thermostat, switch and wiring
Misc. Engine Accessories/Side Exhaust:
Exhaust/Mounts: The Type 65 base kit is configured to accommodate the Ford 302 or 351W engines. Kit comes with alternate drive pulley assembly, and exhaust assembly to adapt Mustang engine and headers to vintage side exit exhausts.
• 4-into-2 Side Exhaust, bare steel with rubber hanger brackets, gaskets and fasteners
• J-Pipe header-to-side exhaust adapter, optional catalytic converter replaces this part. Full tubular headers are also an available option.
• Alternate drive pulley, spacer, pulley wheel and fasteners
• Air filter, conical
• Custom length fan belt* with fasteners
• Universal accelerator cable assembly includes cable, return spring and retainer
Gauges and Dash and Electrical Assembly:
Base kit includes gauges, and parts to adapt Mustang wiring harness. The Base Coupe kit also comes with an authentic style dash, indicator lights, switches, and horn.
• Type 65 Coupe style aluminum dashboard with fasteners
• Red, green, blue dash indicator lights
• On/Off switch, horn button, flasher and connectors
• Complete set of 7 Autometer brand electronic gauges, with connectors, terminals and installation kit. Includes the following gauges:
- Speedometer
- Tachometer
- Oil Pressure Gauge
- Water Temperature Gauge
- Fuel Level Gauge
- Voltmeter
- Oil Temperature Gauge
So, that sounds like a lot of parts for around $16k. Is there any thing else besides what the website says which is a doner Mustang, engine, tranny, wheels?
You can put a chebby engine into a Ford body, but it will NEVER be a chevrolet. It also shows you're ignorant, and lack imagination, as in its been done to death as in its not an original idea.
Old 09-05-2013, 03:38 PM
Rich A's Avatar
Here’s a list of what Does Not come standard in the Factory Five Racing Type 65 Coupe, Base Kit. Donor build.
Major Parts from ‘87-’93 Mustang
• Engine and transmission
• Driveshaft
• Ford 8.8” rear end with quad-shocks, brakes, springs and control arms
• Mustang front and rear brakes
• Mustang spindles/lower A-arms
Minor Parts from ‘87-’04 Mustang
• Steering rack with factory ignition
• Ford EFI computer and wire harness
• Mustang fuel tank and fuel filter
• Mustang E-brake handle and pedal box
Other
• Wheels, Tires, and Paint
• Silicone sealer
• Fluids (oil, grease, coolant, water, gas)
• Chassis harness
Old 09-05-2013, 03:39 PM
LMH's Avatar
LMH LMH is offline
The kit is pretty complete. There's much assembly to do, much more than the roadster.
You'll also need to add paint/body work. There's a lot of body to work on too. Lots of fitting and trimming to make it all fit. The sky is the limit for cost on paint.
Brakes and some also add air conditioning too.
Alba gu brΰth
