Like Tree1Likes
  • 1 Post By Mark IV
Old 09-23-2013, 02:22 PM
Default Safety wire tool size and type
What size safety wire pliers will work well for spinner safety wire? I want to buy a good US-made pair of Milbar pliers (used) and am wondering if the 6" model will do the trick. I found a pair at a really good price. Also, are the basic, manual, clockwise pliers good, or is it worthwhile to get the reversible, automatic return ones?
Old 09-23-2013, 02:33 PM
fordracing65's Avatar
Finishline...
PRIDEnJOY
Old 09-23-2013, 02:46 PM
Originally Posted by fordracing65 View Post
Finishline...
I'm sure they're fine, but I can get US-made tools at the same price if I buy used. I'm getting pretty sick of Chinese (lack of) quality.
Old 09-23-2013, 04:33 PM
Agreed...
PRIDEnJOY
Old 09-24-2013, 08:39 AM
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Default tools
Buy whatever safety pliers you can afford. You only use them on the knock offs.
In fact, regular vise grips will do the job.
The Nut
Enough is enough. Too much is just right ( C.S )
Old 09-24-2013, 12:51 PM
Senile Club Cobra Member
We use .041 stainless wire....your results may vary.
601HP likes this.
rick@autoventureusa.net
Old 09-24-2013, 03:46 PM
X2!
Old 09-25-2013, 07:11 AM
Danr55's Avatar
I use .021stainless wire. It's easier to work with and not as rigid as the heavier stuff. Looks better too. For tools I use a pair of duckbill pliers with push rods from a 2800 radial welded to the handles. Reality easy tu use and a lot handier than the twisting kind.
Dan in Arizona
CCX3209
Old 09-25-2013, 09:26 AM
The wire ERA supplied is .031" (I think). I wired the rear wheels last night and the HF tool worked ok, but it's a cheapie and life's too short to use Chinese tools. I ended up buying a Milbar 11W (CW only, 6") for $20 (including shipping) on Ebay. I'll let you know how they compare once it arrives.
Old 09-25-2013, 02:27 PM
Lots of opinions on the subject of safety wire size. The info below was taken from the PEGASUS Auto Racing Supplies web site.
Part No.: 3129-Size
Stainless Steel Safety Wire, 1 lb. Spool
Safety wiring remains the most positive and assured method of securing critical fasteners. Our 1 pound spools of type 304 stainless steel safety wire are supplied in tangle resistant dispenser packs. Packaged by weight, so lengths are approximate.
Safety Wire Size Recommendations
Application
Size
Tightly spaced fasteners less than 2" apart
0.020"
(double strand)
Small screws drilled smaller than 0.045"
0.025"
General Purpose
Double-twist wiring of most #10 to 3/8" diameter bolts
0.032"
Large fasteners
0.041"
Single-Wire Method
Use the largest diameter possible
