Like Tree1Likes
  • 1 Post By Shootnride
Old 09-24-2013, 07:17 AM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
Default Checking Sidepipe Temps
Just wondering if you guys check the temperature of your side pipes regularly. I did a very quick check of mine yesterday. Found out afterwards that Mothers aluminum polish does quite a good job of removing charred shin skin
Ted
427 sam likes this.
Old 09-24-2013, 07:18 AM
xlr8tr's Avatar
Cobra Make, Engine: CAN-AM cobra, 460 SVO
LOL! been there done that...
Mark
Old 09-24-2013, 11:10 AM
427 sam's Avatar
Cobra Make, Engine: Dax -fuel inj 383 chevy
Send a message via Yahoo to 427 sam
HE HE been there done that, also as an after thought Quick lift jack do a fairly
good job removing skin and flesh, Regards Sam
Old 09-24-2013, 11:57 AM
Cobra Make, Engine: 1966 Classic Roadster
I still have a nice scar on my left leg from the very same thing. I have since has Bill Emerson from Emerson Motorsports, Redding, Ca put new mufflers in my exhaust and has wrapped them (around the muffler but inside the polished tube) with some new insulation he's come up with. They still get hot but not even close to before. You can actually briefly touch the exhaust without a burn. Well worth looking into. Mine is the first car he's tried this insulation on and it really does make a big difference. Good luck
Old 09-24-2013, 12:32 PM
Mine gets up to 340 at the collector merge and 160 at the exit cut. They're coated stainless. Headpipes 450-500; 800+ at the flange.
Chas.
Old 09-25-2013, 05:11 AM
mdross1's Avatar
Mother in law once jumped on our Harley with nylons on to show friends how she loved our bike just as we pulled into a family function. The skin and nylon mix would not polish off.From that day forward all our Harleys exhaust was painted black.
Mother in law loved to explain her new tattoo.
Old 09-25-2013, 06:48 AM
Shootnride's Avatar
Well, I'm glad to know that I'm in good company and that I'm not the only one who has moments of brain fade
I'm enjoying reading others experiences with the sidepipes. I'm starting to appreciate the under-car exhaust systems.
Greg,
Wish I had known about the insulation you had done on your pipes about a month earlier. I just paid a pretty good sum to have mine ceramic coated and I'm pretty sure the SPF pipes would have to be cut open and re-welded to do the insulation.
ERA Chas,
I'm pretty impressed that you actually KNOW the temps of your pipes. I suppose I could assume that mine are somewhere in the ballpark of those temps. Kind of explains why those skin transplants happen so FAST
Ted
Old 09-25-2013, 07:34 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
If your pipes are a polished silver ceramic I've had some success with heating the pipes/foreign material up with a heat gun and using 4O (OOOO) steel wool to gently scrub off the foreign material. Let the pipes cool completely and then use some more 4O and Mother's metal polish to clean up the rest. The 4O is softer than the ceramic coating and will clean/polish but not scratch.
Like most warnings on cleaning products try in a small unobtrusive spot first to make sure it functions as advertised.
DonC
Old 09-25-2013, 08:15 AM
Originally Posted by Shootnride View Post
ERA Chas,
Ted
Assuming your compression and timing are similar to mine and you have coated stainless pipes.
Non-Contact Infrared Thermometer with Laser Targeting
There are plenty of brands and prices to choose from.
Chas.
Old 09-25-2013, 08:40 AM
Al G's Avatar
Cobra Make, Engine: Sold - Shelby Cobra CSX6045, 468 ci all aluminum Shelby engine
Are those temps at idle after some run time or at some throttle level?
Old 09-25-2013, 08:48 AM
Idling after hard running. Water 220, oil 230, 93 octane.
Chas.
Old 09-25-2013, 09:27 AM
Cobra Make, Engine: ERA #448, 1964-427
Hi Guys, Wrapped the muffler section on my chrome side pipes on my ERA with fiberglass header wrap then put a set of covers from Finishline over the muffler. Though quite warm to the touch, not scaulding enough to burn you. Even after a long drive. The "Boss" approves.........
Old 09-25-2013, 02:06 PM
Cobra Make, Engine: Superformance #522
Found very similar temps on my car with a thermal imager.
Old 09-25-2013, 06:51 PM
mickmate's Avatar
You don't need any temperature measurement devices, take them to a car show and use kids shoes to test them............
mickmate
http://www.actoncustom.com/
