Old 11-26-2013, 03:41 PM
rgnbull1227's Avatar
Cobra Make, Engine: Superformance SPF2271
Default Winter and Cold Garages
I was wondering if there are any issues with keeping a Superformance or any Glass car for that matter, in an unheated garage. Garage never gets below freezing but it does get into the 40's.
Thanks.
Old 11-26-2013, 04:18 PM
Thanks.
I have never even heard of an issue with a glass car and chilly temps -- or even COLD temps, for that matter.
Old 11-26-2013, 05:40 PM
twobjshelbys's Avatar
I think boats do nicely in all weather conditions.
So do Corvettes.
Tony
CSX4005LA
Old 11-26-2013, 05:35 PM
Cobra Make, Engine: Backdraft 351W Balanced/Blueprinted 360HP / Tremec 5 Speed
Fiberglass likely not the issue. Watch for mold/mildew inside the car on leather, soft top and other natural fabrics due to temp changes.
Old 11-26-2013, 05:39 PM
TN Shelby Cobra's Avatar
Cobra Make, Engine: Superformance # 1774 / 392 Stroked Windsor
Luckily my garage I keep the Cobra in is heated and air conditioned. I agree about the mildew in the interior. I get that in my boat when it is stored.
Old 11-27-2013, 03:45 AM
mdross1's Avatar
Our car like all our other hobby investments sit out the sub zero conditions in a shop year after year without any issues other than the horrible fuel we are forced to use.The Cobra has a lightweight cover for dust control and is always meticulously maintained,the battery tended.
Old 11-27-2013, 06:10 AM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
Stabil in the fuel, 35 pounds in the tires, pull the battery and put it in a warm place with a tender, throw a cover on it and kiss it good night for the winter.
My shop is not heated unless I'm in it and it does get below freezing in there.
Meanwhile, I'm in Florida.......................messing with motorcycles and flats boats.
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
Old 11-27-2013, 06:05 AM
Cobra Make, Engine: Shelby, 1964 CSX2367, fully restored, I'm the second owner, SAAC Div 1 Premiere 2003&2012
I needed to store one of our collector cars in an unheated garage for two years when I was working outside the US for a while. I used this storage bag that you pull the car into (a little cumbersome to do), put some big bags of desiccant in the car, extract all the air from the bag with a vacuum cleaner, then seal the bag with this huge twisty clamp. It worked remarkable well. I recall the kit costing maybe $200, and it's reusable.
I think the damage to a car in a unheated garage occurs when the temperature passes thru the dew point, and condensation forms inside cavities and on unprotected surfaces. That, and varmints. We've all seen nests and cobwebs....
Dave Wathen
1964 CSX2367
1938 Jaguar SS100
1953 XK120 roadster
1966 Etype roadster
1971 280SE 3.5 Cabriolet
Old 11-27-2013, 06:37 AM
Thanks. I thought I saw somewhere on this forum that the glass cars had an issue with temp changes and glass material "shrinking" due to cold temp swings creating blemishes in the finish.
I thought that sounded odd with the amount of Vettes and other glass cars out there and never hearing of this issue before.
Thanks again.
Old 11-27-2013, 07:10 AM
Yes, I have seen that before, but only with really crappy "backyard" paint and body work. When we were youngsters, and did absolutely everything ourselves, and often times not that well (even if it initially looked good), paint and body work would crack and blemish under harsh weather conditions. We're a lot older now, and the quality of the paint and body work is just a wee bit better.
Old 11-27-2013, 08:16 AM
I have a large (36x50) finished garage, with a furnace. I normally keep it set @ 35 F. At Christmas time, I have a large family dinner, with lots of children. So I heat and clean the garage up for the dinner.
I am a bit careful on heating the garage up. I make sure the Cobra is not placed in an air stream. I heat it up 10 deg and let it stay there a couple hours then step up another 10 until I get to the desired temp. I have to clean anyway and prefer to work in the cooler temp.
I have heard of people cracking paint on Corvettes by cranking a furnace up full blast on a cold day. Don't know if it is true, but thermal expansion is real. Too fast may be a problem.
Old 11-27-2013, 08:22 AM
GBowman's Avatar
Cobra Make, Engine: BDR #1230/B2 445CI SBF
I just started using Flatstoppers under each tire for long storage periods, they are cheap and keep tires from developing flat spots.
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
