Old 01-02-2014, 10:50 AM
mjhcobra's Avatar
Cobra Make, Engine: Everett Morrison, 428
Default Methods for connecting the wiring harness to the body
Hi guys,
Anybody have any simple ways to connect the wiring harness to the body in the engine compartment where you cannot bolt thru the shell? The firewall is not a problem, but connecting the harness to the fenders is. I considered using epoxy to connect a 1" x 1" plastic tab to the underside of the fender out of sight and then using a cable tie to connect the harness to the tab.
Any thoughts would be helpful.
Old 01-02-2014, 11:16 AM
That's exactly what I did.
Ron61's Avatar
Post
That would work and is pretty much the way I did mine. But make sure you use a good glu. I used E6000 which takes about 18 hours to get completely set, but once it is, it will never come loose. I also used very light body clamps to put my harness in as I was trying to save weight.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 01-02-2014, 03:22 PM
CHANMADD's Avatar
Summit has them......Cable ties with base.........
Old 01-02-2014, 04:20 PM
frdfver's Avatar
Cobra Make, Engine: N.A.F., 351 cleveland, 9" ford
If you would rather us a clamp than a cable tie these studs work good from Aircraft Spruce. Kits come with the adhesive but I have put them on with other epoxy adhesives.
CLICK BOND STUD KITS from Aircraft Spruce
Paul T.
Old 01-03-2014, 07:53 AM
mjhcobra's Avatar
looks like I was on the right track. I do like the stud application also.
Is there a particular wire loom that was used back in 65 or is the generic split plastic loom the answer?
Thanks guys for the help.
Martin
Old 01-03-2014, 02:50 PM
Average Guy
I used Liquid Nails construction adhesive on the back of the plastic cable ties. It has stayed put for 22 years.
Old 01-03-2014, 03:38 PM
ItBites's Avatar
Click studs. When applied properly they rock. We use them on rockets that go to the space station and the moon. They work pretty good...
E. Wood
ItBites
Old 01-03-2014, 07:04 PM
Rick Parker's Avatar
10-32 Nutsert and an insulated Adel Clamp. Small, tidy, all that shows is the band of the clamp and the Stainless screwhead; and they are removable if necessary.
Old 01-12-2014, 11:58 AM
mjhcobra's Avatar
Thanks for the ideas. I ended up welding a 10-32 screw to a 1" diameter washer and using epoxy to adhere the stud plate to the underside of the fenders. Attached rubber insulated clamps to the studs with locknuts. Clean and out of the way.
