03-29-2014, 11:13 AM
VA
Why would this FE unit not fit on a SBF
Everything looks the same????
[ame="http://www.amazon.com/Champion-Aluminum-Expansion-Reservoir-1958-1969/dp/B00AOCV50I/ref=sr_1_1?ie=UTF8&qid=1396113050&sr=8-1&keywords=Champion+CoolIng+Systems+expansion+tank "]Amazon.com: Champion CoolIng Systems, CC64GLT, All Aluminum Radiator Coolant Expansion Tank Overflow Reservoir for the 1958-1969 Ford FE Engine: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41bNkubIZnL.@@AMEPARAM@@41bNkubIZnL[/ame]
________
________
03-29-2014, 11:29 AM
KY
Flange is different.
03-29-2014, 03:55 PM
Cut, weld, grind. Cut again, weld again, grind again. Make it work.
Karlos
03-29-2014, 04:23 PM
VA
too bad
Its a nice unit for a good price. I wonder how far off it is. Maybe just elongate the holes and it will fit ???????
________
________
03-29-2014, 05:07 PM
KY
The holes are mirror backwards. On a Windsor, the passenger side hole is higher, on the FE, the driver's side hole is higher.
03-29-2014, 06:14 PM
Cobra Make, Engine: Superformance, 427SO
This should be very easy to resolve with a flat, square, adaptor plate that has both bolt paterns if there is clearance for the square plate. Through-bolt the tank flange to the adapter plate, then bolt the adapter plate to the engine. Gasket both sides.
Ted
03-30-2014, 12:05 AM
Ca.
looks like its to tall...
03-30-2014, 05:12 AM
It would depend on the car and radiator design but for an ERA the radiator hose connection is on the wrong side also.
03-30-2014, 04:33 PM
UK
why not use the FE-like header tank that fits small blocks from Finishline?
