Old 06-03-2014, 08:34 PM
GT350Mike's Avatar
Cobra Make, Engine: CSX6363
Default Another Speedometer gear selection question
After using the gear selection calculators I found on several different sites, the results recommend using either a 17, 18, or 19 tooth gear. My tires are Billboards and have a 85" circumference, the transmission is a TKO 600 transmission (assuming 7 tooth drive gear), and the rear-end ration is 3.31.
Any suggestions???
Old 06-04-2014, 07:14 AM
DougD's Avatar
Do you have a GPS? Garmin or similar? If so, take it for a short drive and document the difference between the indicated speed on the GPS vs your speedo.
It's simply a proportion to calculate which gear to use. If you're off by 10 percent, them substitute a gear with 10 percent more or less teeth to correct. More teeth slow it down, less teeth speed it up.
Let us know how it goes.
Doug
Old 06-04-2014, 07:57 AM
Cobra Make, Engine: 1966 Classic Roadster
If you don't have a GPS etc you can download a free app on your cell phone (smart phone). Thats what I did and it works great.
Old 06-04-2014, 09:37 AM
I also used a few free iPhone GPS programs to calibrate my speedo and select gears. I think I ended up with a 20 tooth gear.
Old 06-04-2014, 10:38 AM
GT350Mike's Avatar
I left out one important fact; the car is about 98% complete. This weekend I'm installing the speedo cable with the reverse gear box along along with a few things in the interior, then the car will be ready for the alignment shop.
I'm planning on ordering the speedo gear today but wanted to avoid buying two or three. If I had to select just one, I'd go with the 19 tooth (pink).
Doug, I know you have BBs and a TKO trans so do you recall which gear you have?
Edit: forgot to ask what rear-end ratio is in your car.
Old 06-04-2014, 02:40 PM
Cobra Make, Engine: Backdraft, Roush 342r
Order a SpeedHut GPS run speedo and there is no need to worry about the gearing or tire diameters. They have a reverse speedo for about $300.
Old 06-04-2014, 05:20 PM
GT350Mike's Avatar
I have heard of GPS speedos and appreciate the info, but I already have the cable and the reverse gear box. It would be really cool to have the GPS technology in the car, but I'd like to keep the speedometer that came with the car. So, do I go with the pink gear or something else?
Old 06-05-2014, 05:59 AM
Dwight's Avatar
Smile
The calculator that I used called for a 17 tooth if the drive gear is a 7 tooth.
Dwight
Old 06-05-2014, 07:31 AM
DougD's Avatar
I'm running a 21 tooth gear right now and it's still a bit off.
You may have to just pick one and go with it. The gears aren't expensive - buy the one you calculate to work and one or two extras with more and less teeth. It's only about a 10-minute job to switch the gears.
