Old 06-04-2014, 03:11 PM
blown871's Avatar
Cobra Make, Engine: SPF
Default Safety clips vs. wire
Is anyone running these clips?
http://vintagewheelsus.com/index.php...age=page&id=19
Or.. a type of set up like this?
Fairly easy to drill the holes?
Old 06-04-2014, 03:17 PM
Cobra Make, Engine: unique motorcars, 289 HO Sold, BDR
can't read reason for the tape.
Old 06-04-2014, 04:40 PM
blown871's Avatar
Link:
1 x set adapter/spindle safety clips : Vintage Wheels, Hot Rod and Muscle car
Old 06-04-2014, 04:53 PM
Cobra Make, Engine: BDR, 302
I purchased a set of wheels and tires with these clips. The holes were pre-drilled. Vintages doesn't recommend using in lieu of safety wire. It adds another layer of safety.
Old 06-04-2014, 05:11 PM
blown871's Avatar
ahh. gotchya.
I did see some cars running at the GLEN last year with only the clip.
Old 06-04-2014, 05:28 PM
DanEC's Avatar
I'm running both also. If I were to use only one I think I would run the safety wiring. The spinner can back off quite a bit with the clips, and even if it stays with the vehicle, the pins or wheel drillings will probably be damaged and wallowed out if it isn't noticed pretty quickly.
Old 06-04-2014, 06:07 PM
blown871's Avatar
good point.
I think of the MG my dad had when I was a kid... no safety wire... no clips.. never a thought.
Old 06-04-2014, 06:43 PM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
Yeah, I always wondered why all the other cars like Jags, MGs, Triumphs, etc with knockoffs did not use/need safety wire. Could it be that they were splined hubs with closer tolerances and maybe finer threads on the spinners ? Anyone know ?
Old 06-04-2014, 07:29 PM
Cobra Make, Engine: ERA #766, FE V8, Toploader
My "old" 1952 MG TD and my current 1957 MGA both use finely splined hubs and relatively fine threads (12 per inch) on the knock-offs themselves. I use a lead hammer to check each "spinner" before and after every run and have never experienced any loosening.
Regarding my ERA 427 Cobra, I "indexed" my wheels to their best fit on the "pegs" (so five or six positions must be tried, depending upon the chosen type) to ensure that the wheel is truly flush with the hub. There is usually only one best fit from all of the positions. If this is not done, then the knock-off will never be tight enough (and will need to be continually tightened), handling will have "variations," and unusual tire wear will ensue. Once you find the best position, always keep the wheel in that same position relative to its hub.
If the indexing is done correctly, then no problems should occur. I use the same lead hammer previously mentioned to check each "Cobra spinner" before and after each run (longest run: 400 miles, with another check at a gas stop; total mileage now 1100 after one year post completion), and I have yet to experience any loosening of the knock-offs. I recently received the R-clips from Vintage Wheels (the manufacturer of my wheels) and I will add them just to be complete, but I choose to not mar my wheels with "safety wire" when I've had no problems for nearly 30 years with this type of wheel retention system. Any driver of these cars likely has the skillset necessary to recognize a knock-off coming loose and should have time to slow to a stop before the R-clip can wear through (which it probably would, given enough time to generate enough heat).
Bottom line: use the lead hammer regularly and consistently, and make sure that your wheels are properly indexed to their respective hubs.
Old 06-04-2014, 07:54 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
I'm wondering if back in the day when running in a race that required tire changes, or any race for that matter, there could not have been any wires. I expect when the spinners are put on properly the chances of them coming off are low. Since we don't want to be the one in a million with spinners coming off we have safety wires. I'll bet they are mostly for show.....
Old 06-04-2014, 10:10 PM
Rick Parker's Avatar
WardL
The 3 ear knockoff was the norm in the 50's & very early 60's on the Indy Roadsters that used the Kidney Bean type Magnesium Wheel. Pit stops were as fast as possible using a lead hammer. No clips or safety wire at the time.
Rick
Old 06-05-2014, 05:24 AM
Cobra Make, Engine: CR Cobra 3169
Were knock offs primary designed to be on a race car, for speed of removal?
Or are there are advantages with knock offs?
JD
Old 06-05-2014, 05:52 AM
Bill Bess's Avatar
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Based on my experience...First of all, the knock-off spinners are always "wickedly tight" and hard to loosen. Second the safety wire is pretty cool looking, and lastly , a quick glance at your wheel..... the safety wire tells you....."the wheel is on tight".
Bill
Failure is not the outcome, it's not trying.
Old 06-05-2014, 09:42 AM
streetrod1927's Avatar
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
I have a similar set of clips on my Halibrand K/O's and also run safety wire on all four.
Old 06-05-2014, 06:39 PM
WardL's Avatar
Oh, I always run the safety wires on the street. I don't put the safety wires on when I'm doing autocross with my autocross tires/wheels.
