Old 07-26-2014, 06:11 AM
505stang's Avatar
Cobra Make, Engine: B&B 351C
Default tranny help
I have a 351 cleveland with a tko 600, i am using a centerforce flywheel and a ram clutch,#98794hdt, using a wilwood slave cylinder and master cylinder, problem i have is when i depress clutch there is like a squeel noise, and it only does it when i depress clutch, also i can not get tranny in gear, slave cylinder does move the throwout bearing, but it looks like it does not engage the the fingers on the pressure plate enough. I took the tranny out to inspect everything and the only thing i can see is where the throwout bearing is touching the fingers, this is a new build so car has never been driven, i am also using a mustang clutch fork. How much should the bearing move the fingers on the pressure plate, and any ideas on the noise? Man i am lost on this one. The noise i think is the bearing touching the fingers. There is no evidence of any grinding, or metal shavings from any interferance problems. Also it seems the harder i push on the clutch the louder the noise. Everything is all new and was hoping to finally drive it this weekend but that is not happening Any help i can get i need!
