January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree60Likes
  #41 (permalink)
Old 09-05-2014, 08:49 AM
NewYorkGuy's Avatar
Cobra Make, Engine: Nissan
Is it cheaper in cost(labor & time) to plate a glass body than to start with an alum body?
The wise man’s life is based around, Fudge You.
  #42 (permalink)
Old 09-05-2014, 12:05 PM
P-51 Cobra's Avatar
Cobra Make, Engine: ERA #644 428FE
I haven't priced comparably equipped ERAs and Kirkhams recently, but I don't think you can do this for less starting with a Kirkham. Besides, we owned an ERA.
P-51
  #43 (permalink)
Old 09-05-2014, 12:23 PM
Cobra Make, Engine: ERA 148 Nightwatch Blue
Carmine no stress cracks or spidering in over 75 cobra hoods like the one in the attached photo. We contribute this to the polymer undercoat.
I plated the underside of my ERA hood over 20 years ago and it looks exactly like it did when it was first done and it gets way hotter than anyonther panel on the cobra.
Newyorkguy,
The cost is probable equivalent to an aluminum body but our goal is not to try and replace any real metal surfaces but rather an alternative to it like in this case the fiberglass body was correct , fitted and in great shape not to mention way stronger than sheet aluminum. Its very hard to dent! I'll try to upload a video that would make a sheet aluminum bodied cobra owner cringe. I take a piece of PVC pipe and smack it down on a plated aluminum over fiberglass fender and no dents or damage to the fiberglass, now that's not saying if you drive the cobra into a wall that the fiberglass isn't going to crack but I'm saying the glass is less susceptible to minor dents.
  #44 (permalink)
Old 09-08-2014, 02:23 PM
Finished the first of our three step polishing process to the entire aluminum plated body , now we can start setting up the panel lines and fastener details.
We first have to figure out the placement of the panel lines and between Buzz's concept drawing and some fullscale P-51 photos that I took at the Oxford airport yesterday, the masked lines only had to be move a few dozen times :-) but we got it figured out.
I took these close up photos of the panel lines, flush rivets and cowl fasteners of the fullscale Mustang. The Collings foundation was nice enough to let me take the photos of their Betty Jane.
As you can see the panels are tight and the flush rivets can only be seen when your close to the aircraft. The removable cowling fastener are larger and protrude about 1/64 of an inch above the surface.
  #45 (permalink)
Old 09-08-2014, 07:31 PM
P-51 Cobra's Avatar
Ron,
It's looking great!
So you'll do the panel lines and rivets next, and then do the second and third stages of polish?
P-51
  #46 (permalink)
Old 09-09-2014, 03:25 PM
The panel lines were completed today. Now it's going back to have another round of aluminum plating applied to specific areas that we marked off as a raised panel.
Once it's back we will polish out those panels and then add the fastener details.
After all the metal detail is finished we will then give it the second phase of polishing which not only will remove all the hand prints from working on it but also bring up the shine a few more notches.
This is a panel line that my son in law just applied and with the rivet details it will look just like the full scale.
P-51 Cobra-- I'm almost finished with your custom directional lights!!!
They look great!!! Photos soon
  #47 (permalink)
Old 09-10-2014, 05:45 AM
P-51 Cobra's Avatar
Ron,
Can't wait to see the lights!
P-51
  #48 (permalink)
Old 09-10-2014, 08:41 AM
Senior ClubCobra Member
This is really cool.
  #49 (permalink)
Old 09-10-2014, 09:38 AM
Do your score the lines into the panel? You show us the progress but little about technique. Or is that a guarded secret? I can't possibly replicate what you do, but I'm always willing to learn how stuff is done. Looking forward to see how the rivets go on... terrific thread and end product!
  #50 (permalink)
Old 09-10-2014, 10:02 AM
Sorry about that,,, here's a photo that shows how we are applying the panel lines and rivets. It's a technique used in the modeling Industry and we found that it works for us too. We use a hot soldering iron with shaped tips.
The heat transfers through the metal into the polyimer undercoat and it softens. Our metal just follows it down into the recess. It takes a little practice to get the depth right but we learned that with an adjustable temp on the iorn makes it much easier. We also use thin aluminum that we buy in sheet, cut it to size and use it as a straight edge.
The raised panels are nothing more than another layer of metal.
dallas_, ACademic and RockBit like this.
  #51 (permalink)
Old 09-10-2014, 02:54 PM
Tenrocca's Avatar
I love this. One of my favourite threads ever. Keep it coming....
  #52 (permalink)
Old 09-10-2014, 07:45 PM
Up until now this has been pretty standard and for us a straight forward plating project, just larger! Now the fun behings!!!
We decided to not only added flush rivet but to stay true to
Buzz's concept we are added Dzus fasteners and raised rivets but again in a subtle manner. The full scale Mustang used raised rivets were extra strength was need and accounted for about 10 pecent of the total rivets used so we are adding them sparingly.
If you look close you can make out the flush rivets too.
I think the Dzus fastener are going to this over the top!!
FatBoy and PhoneGuy like this.
  #53 (permalink)
Old 09-11-2014, 02:42 AM
P-51 Cobra's Avatar
You guys are real artists!
Metal-morphous likes this.
  #54 (permalink)
Old 09-11-2014, 07:55 AM
Cobra Make, Engine: spf 2112 *427 stroker windsor
Really impressive.
My hat off to all involved.
With the attention to detail thats going into this cobra i hope the windscreen thats in the renderings come into play as well.
  #55 (permalink)
Old 09-11-2014, 10:29 AM
How are the raised rivets fastened? Are they just faux heads with adhesive or do they go through the body? Incredible detail.
  #56 (permalink)
Old 09-11-2014, 10:48 AM
Buzz's Avatar
The attention to detail you are putting in will turn what could have been an amazing project into an absolute masterpiece. Beautiful work - can't wait to see more.
Buzz
Tropical Buzz
  #57 (permalink)
Old 09-11-2014, 03:53 PM
jolsen42's Avatar
John O
jjo42
  #58 (permalink)
Old 09-12-2014, 02:12 PM
Dzus fastener were a little more challenging, first we pulled a mold from a full scale fastener. Then we fabricated our own from plastic and plated them in aluminum. Next we recessed them just below the top surface and epoxied them in place. They sit-up just above the top surface and look exactly like the ones used on the P-51.. The last stages of polish will add a nice highlite to them. Only 84 more to go :-)
  #59 (permalink)
Old 09-12-2014, 04:25 PM
dallas_'s Avatar
Dang. That's just cool as hell.
  #60 (permalink)
Old 09-12-2014, 05:42 PM
"Paging Mr. Metal-morphous...Mr. Metal-morphous, SEMA is on the other line. They want this car done and delivered to Las Vegas by November 4th."
