Old 09-28-2014, 04:32 AM
Default HELP finding a Blue Thunder 427 MR Intake Manifold
Hi,
I'm having an issue with my current intake and am having difficultly locating a new or used Blue Thunder 427 Medium Riser dual plane intake manifold for the past several months.
I've called several BT suppliers and no one seems to have one in stock nor can advise when they will receive one.
Does anyone know of any available?
Thanks in advance for your help.
Old 09-28-2014, 05:02 AM
Default 3 guys I can think of
ERANJ Try Barry Robinick, Jay Brown on the FE forumn, Brent Bylkins. I would also check e-bay, craigs list, FE forumn, FE power forum. May have luck there. Rick L. Ps what is the matter with the manifold you have?? If aluminum it can be repaired. If rotten or leaking at the coolant ends, Use J-B welding 2 part epoxy. Tubes in the ports with vacuum leaks same thing. Call me 732-254-3536
Old 09-28-2014, 05:03 AM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Edelbrock makes a nice FE duel plane Air Gap 2x4 intake. Also at a fair price. It can be viewed via Jeg's
