Like Tree5Likes
Old 10-26-2014, 04:48 PM
cobrakiwi's Avatar
Thanks Jeff,
I have done a few of these now and it's always nice to step back after the job and feel good about the work or product.
The bigger satisfaction for me is knowing the customer is happy with the work.
Old 10-26-2014, 04:49 PM
I don't have metal bending and cutting equipment. I tried to fab some small pieces in the past, and wasn't satisfied with the results. cobrakiwi is able to produce the high level of finished product that I want. He at least left me the final fitting and riveting, but I had to twist his arm, LOL! That battery tray mock up is simple and clean. I like it!
A few posts back in this thread show the fresh air tube hangers he fabbed. When he discovered I had used zip ties to hold the air tubes in place, he was polite in the way he told me my approach was sub-standard!!
Old 11-08-2014, 03:54 PM
cobrakiwi's Avatar
Enjoyed your visit the other day, now you have your ride home time to get to work and bolt every thing back together.
Your new engine sounds incredible by the way, it should have no problem pushing the HiTech down the road, that's for sure!
Old 02-13-2015, 11:22 AM
cobrakiwi's Avatar
Default follow up with parts
Here is a follow up on a couple of parts we supplied for David's HiTech,
David takes great pride in is workmanship, and boy does it show!
These slim line batteries fit behind the seat with room to spare.
New Dash all covered and looking great with the gauges, lights, switches etc installed.
Old 03-22-2015, 12:36 PM
cobrakiwi's Avatar
More work on the HiTech, the alloy panels we made up for David are now installed.
The interior is starting to come together quite nice.
Buzz likes this.
Old 03-22-2015, 12:41 PM
Buzz's Avatar
Beautiful work!
Tropical Buzz
Old 03-23-2015, 11:45 AM
cobrakiwi's Avatar
Thanks Buzz.
We installed a new set of better flowing mufflers so the new engine can breath.
The old rubber engine mounts had collapsed enough to the point of the pipes hitting the body so we made up a set of engine mounts as well.
Old 03-27-2015, 11:08 AM
cobrakiwi's Avatar
Picture of inside trunk, Roll bar installed, test fitting batteries, David will be making up new cables for the batteries next.
Old 03-27-2015, 01:16 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Looks AWESOME!!! Cant' wait to see it in person.
Old 03-27-2015, 01:38 PM
1985 CCX's Avatar
Way cool.... So in envy
Old 04-25-2015, 12:14 PM
cobrakiwi's Avatar
David has been working hard on his HiTech.
Things are coming along very nicely.
Old 04-25-2015, 12:24 PM
cobrakiwi's Avatar
The interior is all wrapped up,
I think Davids hard work has paid off.
Well done, it looks great.
  #33 (permalink)
Old 04-25-2015, 05:44 PM
DanEC's Avatar
Beautiful work. Well done.
ERA 782 Running
  #34 (permalink)
Old 04-26-2015, 09:41 AM
cobrakiwi's Avatar
David and his wife invited me to there house for the start up of his new engine.
After we finished up a couple of small items on the hit list it was time to start her up.
Wow comes to mind, the engine lit off with out a problem, set the timing, jump in and off for a ride.
David handed the wheel off to me at some point, the engine felt strong and wanted to go.
Off course we held it back and played safe, what a great weekend!
Thank you both for the hospitality.
  #35 (permalink)
Old 05-02-2015, 10:49 AM
gunkk's Avatar
wow! she's beautiful.
motorhead finally found his motor
  #36 (permalink)
Old 05-02-2015, 01:57 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
This is such a badass Cobra.
Cobrakiwi and 601HP did an incredible job.
Hats off!!!
rodneym
  #37 (permalink)
Old 05-03-2015, 10:07 AM
Cobra Make, Engine: owned Kirkham for 11 years
Beautiful
Maurice
  #38 (permalink)
Old 05-03-2015, 11:11 AM
1985 CCX's Avatar
So nice!
Whatta car!
Hope to see it in person some day.... Maybe a SAAC event etc....
  #39 (permalink)
Old 05-23-2015, 09:32 AM
cobrakiwi's Avatar
Thanks for the great comments,
David really has done a great job on this project.
We are having fun coming up with new ideas and trying some proven ideas to try and sort out a few issues that pop up with building and owning one of these cars.
Here is a nice part I made up for the engine fuel system, this fuel log is insulated inside the outer tube, then David powder coated it gray.
  #40 (permalink)
Old 07-08-2015, 11:23 AM
cobrakiwi's Avatar
I made this stainless oil pan girdle up for the big 496 as there where a few small oil leaks, Job well done on the install David.
The following is from David.
My original iron block had an Aviaid pan on it for 20 years. Multiple rebuilds on that block, and multiple new gaskets. Always leaked.
New Pond aluminum block with new Aviaid pan. There were multiple leaks around the pan, a bit more leaking occurred at the rear of pan.
The photos taken today show the oil pan after driving about 180 miles since the installation of the girdle. 130 of those miles were in Arkansas while cruising through the Ozark Mountains last week. There were quite a few runs above 6,000 rpm. There is zero indication of oil leaking anywhere around the pan. The frame of my car has never been this oil-free. Prior to installing the girdle, a 20 mile drive would leave multiple oil drips on the frame.
I feel the Aviaid pan's flange isn't sufficiently rigid to provide uniform clamping of the pan, 2 gaskets and 1 windage tray.
rodneym likes this.
