Old 11-23-2014, 01:05 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Default Need torque specs for drive pin/allen bolts
Anyone know the torque specs for the 10mm drive pin/allen bolts on the Backdraft knock-off adaptor. These are the 5 "lug bolt" replacement allen bolts that hold the knock-off adaptor hat on the original BMW M3 hub rear. No idea what grade the aliens are, no marks on the bolts.
Wayne
Wayne Rogers in Hideaway, Texas
Old 11-24-2014, 05:05 AM
DanEC's Avatar
Vintage recommends 85 ft lbs for pins on 1/2 inch wheel studs with a bit of blue threadlocker. Don't know specific to Backdraft - what size wheel studs do you have?
Edit - just noticed you said 10mm - so 85 ft lbs is too high.
ERA 782 Running
Old 11-24-2014, 07:29 AM
wrogers55's Avatar
Actually, bolt size is 12 mm once I really go to look at it. Looks like BMW recommends 85 ft lbs as well. I used some red high temp on the threads and most certainly will have to heat them next time I remove them.
Thanks for responding.
Wayne
