Like Tree1Likes
  • 1 Post By mickmate
Old 12-11-2014, 09:20 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Default Help!
How do I reduce the gap at the top so I can weld it up?
Old 12-11-2014, 11:44 PM
Cobra Make, Engine: Shamrock
Cut a 1/4 moon fillet from left over pipe and weld in or make a new brace the right length.
Old 12-12-2014, 12:47 AM
Ron61's Avatar
It would lower the brace a little but you should be able to trim some on the rounded edges enough to get it to go flush against the roll bar. From the picture it is hard to see just how high you are on the roll bar and doing what I suggested may lower the brace more than you would want it. Other than that I would go with a new brace as welding in a fillet would weaken it some even if you could polish out the welds to where they don't show.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 12-12-2014, 02:02 AM
Bill D's Avatar
Old 12-12-2014, 03:41 AM
Bill Bess's Avatar
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Any good acet. welder could fill that perfectly, especially if you do a little fitting.
Bill
Failure is not the outcome, it's not trying.
Old 12-12-2014, 04:27 AM
Tommy's Avatar
I think I agree with Ron. If the brace tube is the same diameter as the hoop, I don't see how it could fit any closer with the rounded "ears" sticking out that far. The hoop would have to be a smaller diameter to fit between the ears. I'd grind the brace to fit better even if it meant lowering the contact point 3/8" or so. ..... If I were going to race this car, I'd have a professional do the job. For a street car I wouldn't be as concerned.
Tommy
Previously owned EM Cobra
Old 12-12-2014, 07:20 AM
Bill D's Avatar
Looks like another job for my local hot rod shop to fix *sigh*
Old 12-12-2014, 09:41 AM
mickmate's Avatar
Put a sharpie against the hoop and run a line around the brace, trim to the line.
Bill D likes this.
mickmate
http://www.actoncustom.com/
Old 12-12-2014, 10:46 AM
G-Pete's Avatar
Don't forget to check the clearance for the PA seat and emergency brake....
DRB GT40 MK1 red #49- sold
SPF 2063
Old 12-12-2014, 11:17 AM
Bill D's Avatar
Thanks Pete. Will do
After considerable grinding, fitting, grinding and more fitting, and some more grinding, I ended up with this
Old 12-12-2014, 11:24 AM
Bernica's Avatar
Senior CC Premier Member
These work most excellent!
Products | PipeMaster™ - The Welder's Tool for Contour Fits
Old 12-12-2014, 11:35 AM
Bill D's Avatar
Placed the pass seat in the car. How does this look?
Old 12-12-2014, 12:50 PM
Bill D's Avatar
Cut 2-1/2" off the hoop. How does this look?
Old 12-12-2014, 12:52 PM
Bernica's Avatar
Put a helmet on and take another pic.
Old 12-12-2014, 12:58 PM
Bill D's Avatar
Old 12-12-2014, 01:06 PM
Bernica's Avatar
Looks like you're flush with the hoop. Some are saying hoop is supposed to be 2" higher, but I can't speak to that. Also, are you TIG welding everything or MIG? All chrome molly? Not sure of your intentions, but if you are going out racing hard and risking it all, this can all matter.
Just my 2 cents...
Old 12-12-2014, 01:09 PM
Bill D's Avatar
Just my 2 cents...
Appreciate your helpful feedback. I'm not intending to track the car. Just lots of street driving and mountain twisters with friends. I was planning to MIG tack and have a pro TIG it. Comments?
Thanks
Old 12-12-2014, 01:15 PM
Bernica's Avatar
Yup, do that. Much cleaner welds with TIG. Good luck with it!
Old 12-14-2014, 06:09 AM
G-Pete's Avatar
Now whenever you decide on a soft or hart top - it will fit.
SPF 2063
