Like Tree7Likes
Old 12-22-2014, 12:26 PM
Yep, pretty much sums it up.
My advice as an engine builder is to go a little bigger on horsepower than what you initially perceive as adequate. Most guys will learn their cars in the first year, then will inevitably come back asking how they can add a little more power.
A 600-650 hp FE in these cars is pretty much the sweet spot, IMO.
What is the drive ability at that hp?
Old 12-22-2014, 12:27 PM
Define driveability. It varies from customer to customer.
Old 12-22-2014, 12:36 PM
Starts reasonably well. Does not overheat in traffic. Doesn't load up at idle.
Old 12-22-2014, 12:37 PM
In that case, absolutely.....you can roll with 700-750 hp and not have any of those.
Bernica likes this.
Old 12-22-2014, 12:38 PM
Cobra Make, Engine: owned Kirkham for 11 years
Bill,
Driveabiity is great with 650 or more hp.
19,000 miles and I have loved every mile >
Maurice
Old 12-22-2014, 12:39 PM
I see solid rollers are being used what is the upkeep on that? Have to set lash now and then?
Old 12-22-2014, 12:40 PM
If you buy good parts, check lash every 2-3 oil changes, and have the lifters inspected after 20-25k miles.
Old 12-22-2014, 12:44 PM
Neutral
While we are trading information. What is the approx. weight difference between an aluminum block fe and cast?
That takes a fe engine from 500 to 650hp
Will they run on pump gas
I realize I am talking generalizations, I hope you can bare with me?
Old 12-22-2014, 12:49 PM
About 175 lbs between a new Pond aluminum block and a new Pond cast iron block.
The heads/cam/intake bump the power up.
Yes.
Old 12-22-2014, 12:59 PM
Pond aluminum FE weighs about as much as an iron small block
Old 12-22-2014, 01:03 PM
The aluminum block is sleeved with o rings?
Old 12-22-2014, 01:15 PM
No o-rings.
  #33 (permalink)
Old 12-22-2014, 01:17 PM
  #34 (permalink)
Old 12-22-2014, 01:20 PM
I have not looked into high performance motors in a while. Like 25 years but this is a bit of a change 650 hp with pump gas that is drivable.
  #35 (permalink)
Old 12-22-2014, 01:22 PM
So how do they deal with the different expansion rates of aluminum and steel?
  #36 (permalink)
Old 12-22-2014, 01:53 PM
They are press fit, and fire ring of head gasket seals at top.
  #37 (permalink)
Old 12-22-2014, 03:59 PM
Bill, even at two thirds that number, in a Cobra, your tires just break loose and you spin, spin, spin. You can't hit WOT in the high torque/HP range of your revs, while you're on the street, for more than a second or two at most -- unless that "street" is an interstate highway away from the city. Even then, you're a heartbeat away from wheel spin even when you're above interstate speed limits. Brent's a wonderful engine builder, but what's more is that he is unusually honest while still being heavily mixed up in this peculiar hobby (which is full of crooks, btw). But he still believes that he has to compete, with the paper numbers, against other well-known builders on this site. The truth is, though, he really doesn't....
  #38 (permalink)
Old 12-22-2014, 06:14 PM
Bernica's Avatar
Senior CC Premier Member
Passing a truck on an interstate at 65-70 and jumping on it to get by him almost cost me everything including my life. Once they start swapping sides...well, thank God that everyone just stopped and let me recover it!
True religion Brother!....
LoBelly likes this.
  #39 (permalink)
Old 12-22-2014, 06:23 PM
Just curious what tires are you running?
  #40 (permalink)
Old 12-22-2014, 06:25 PM
Bernica's Avatar
Billboards at the time. Avon's now.
