7Likes
12-22-2014, 01:26 PM
Originally Posted by blykins
Yep, pretty much sums it up.
My advice as an engine builder is to go a little bigger on horsepower than what you initially perceive as adequate. Most guys will learn their cars in the first year, then will inevitably come back asking how they can add a little more power.
A 600-650 hp FE in these cars is pretty much the sweet spot, IMO.
What is the drive ability at that hp?
12-22-2014, 01:27 PM
KY
Define driveability. It varies from customer to customer.
12-22-2014, 01:36 PM
Starts reasonably well. Does not overheat in traffic. Doesn't load up at idle.
12-22-2014, 01:37 PM
KY
In that case, absolutely.....you can roll with 700-750 hp and not have any of those.
12-22-2014, 01:38 PM
Cobra Make, Engine: owned Kirkham for 11 years
Bill,
Driveabiity is great with 650 or more hp.
19,000 miles and I have loved every mile >
Maurice
12-22-2014, 01:39 PM
I see solid rollers are being used what is the upkeep on that? Have to set lash now and then?
12-22-2014, 01:40 PM
KY
If you buy good parts, check lash every 2-3 oil changes, and have the lifters inspected after 20-25k miles.
12-22-2014, 01:44 PM
Neutral
While we are trading information. What is the approx. weight difference between an aluminum block fe and cast?
That takes a fe engine from 500 to 650hp
Will they run on pump gas
I realize I am talking generalizations, I hope you can bare with me?
12-22-2014, 01:49 PM
KY
About 175 lbs between a new Pond aluminum block and a new Pond cast iron block.
The heads/cam/intake bump the power up.
Yes.
12-22-2014, 01:59 PM
Pond aluminum FE weighs about as much as an iron small block
12-22-2014, 02:03 PM
The aluminum block is sleeved with o rings?
12-22-2014, 02:15 PM
KY
No o-rings.
12-22-2014, 02:17 PM
KY
12-22-2014, 02:20 PM
I have not looked into high performance motors in a while. Like 25 years but this is a bit of a change 650 hp with pump gas that is drivable.
12-22-2014, 02:22 PM
So how do they deal with the different expansion rates of aluminum and steel?
12-22-2014, 02:53 PM
KY
They are press fit, and fire ring of head gasket seals at top.
12-22-2014, 04:59 PM
Bill, even at two thirds that number, in a Cobra, your tires just break loose and you spin, spin, spin. You can't hit WOT in the high torque/HP range of your revs, while you're on the street, for more than a second or two at most -- unless that "street" is an interstate highway away from the city. Even then, you're a heartbeat away from wheel spin even when you're above interstate speed limits. Brent's a wonderful engine builder, but what's more is that he is unusually honest while still being heavily mixed up in this peculiar hobby (which is full of crooks, btw). But he still believes that he has to compete, with the paper numbers, against other well-known builders on this site. The truth is, though, he really doesn't....
12-22-2014, 07:14 PM
Senior CC Premier Member
Passing a truck on an interstate at 65-70 and jumping on it to get by him almost cost me everything including my life. Once they start swapping sides...well, thank God that everyone just stopped and let me recover it!
True religion Brother!....
12-22-2014, 07:23 PM
Just curious what tires are you running?
12-22-2014, 07:25 PM
Billboards at the time. Avon's now.
