Old 01-12-2015, 11:35 AM
Club Cobra Member
Cobra Make, Engine: NAF 427
Default A question about IRS design
Does the spindle/upright of a independent rear suspension have any castor designed into it?
Or just the obvious camber and toe-in adjustments?
Just curious.
Greg
Old 01-12-2015, 03:20 PM
Default drive train angle could pass for caster
my427cobra Greg If you have a 4 link setup, it is kind of a caster adjustment. The most important thing in the rearend IMO is equal toe both sides and about -3/4 degree of camber. The thurst alignment of the car should be "0" when done. I do this with the car balanced in the 49/51 ratio of front to rear weights on the corners. This is with your weight in the drivers seat. LIve weight, not dumbbells. My battery is also in the trunk on the right side above the r/r tire. Extra 40 pounds helps with traction. Hope this helps. Rick L.
Old 01-12-2015, 03:22 PM
It's possible for the rear upright to be angled, but it really can't be described as caster since the toe changes are built into the jounce/rebound geometry. If there's a tilt, it is usually a result of practical considerations when building in anti-squat and/or anti-lift.
Old 01-12-2015, 03:27 PM
cycleguy55's Avatar
There's a specific thread on this issue at Independent Rear Suspension Forum » IRS Caster, Is It Needed?
You may want to poke around the IRS Forum, or search on 'caster' or 'castor' Independent Rear Suspension Forum
Old 01-12-2015, 03:38 PM
Club Cobra Member
Great info guys. Thanks.
Greg
