Old 03-04-2015, 05:02 AM
Cobra Make, Engine: FFR MK IV 427W
Default O2 sensor Holley Terminator-left or right
Getting ready to drill and weld the receptacle for the Holley Terminator EFI oxygen sensor. Anyone who has used one , or anyone for that matter, have any recommendation to mount on the left or right side pipe. I am thinking left/driver side???????
Old 03-04-2015, 05:41 AM
I don't think it matters, I would think about running the wiring and make your decision based on that.
Bill
Old 03-04-2015, 06:46 AM
MOTORHEAD's Avatar
Where in the exhaust are you putting it ? Should be in the collector and no more than 90 deg from verticle, which is almost impossible on cobras since most have the collector outside the body which means the 02 bung would be 90 or more deg down from top, and aimed toward the center of the car. It will work in any position, but if mounted from 90 to 180 deg from top position the sensor is more likely to accumulate exhaust residue and cause early 02 sensor failure . I have experienced this.
"When Injustice becomes Law,
Old 03-04-2015, 07:23 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
O2 Sensor Install
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Old 03-04-2015, 08:23 AM
Tom Wells's Avatar
pcww,
I don't think it matters to the EFI which side you use. Nothing in the Holley instructions mentions a preference. Just follow the rest of their O2 sensor location recommendations in the manual that comes with the unit!
Tom
