Like Tree1Likes
  • 1 Post By Rawkkrawler
Old 03-15-2015, 09:18 AM
Rawkkrawler's Avatar
Cobra Make, Engine: Everett Morrison
Default First concerning issue
I say concerning only because it's intermittent and the motor quit thus forcing me to pull over to troubleshoot. No real warning, slightly under load, just a sputter than tach to zero.
Basic info:
Carb'd 5.0 with Quickfuel 650
Mallory Max-Fire distributer (1 year, 1600 miles old)
Mallory coil
Electric fuel pump
First thing I did was turn the ignition on and read the fuel pressure gauge under the hood, it was at 6.5-7lbs. Nothing alarming there. Then I moved the throttle linkage, gas squirt in as usual. I pulled the coil wire and cranked the engine, spark popping like normal. I pulled the distributer cap and cranked it, rotor spun normal. The only thing I did was clean (scrape) the cap contact points a little and put everything back together. It fired right up and drove the 5 miles back home.
I took it out later that night and it sputtered once at a light but didn't stall. About a half mile later it had a loss of power under a slight load. Had it at about 1/2 throttle and it barely maintained 1000 rpm then quit again. I had an overwhelming fuel smell almost bad smelling. This time I was able to restart it by just holding the gas pedal to the floor as it appeared to be flooded. This may not be a symptom as I had the pedal 1/2 throttle right before it stalled.
So, it appears to be either an ignition problem or a bad fuel problem.
All of the wires are connected firmly. I'll double check the ground this morning.
I'm a little worried about the Mallory dist. It's an all in one unit and there is no real way to troubleshoot it I don't think. Is it possible that a worn out dist cap could give me these issues? Seems a little sudden to just shut the car down. I'd understand a lack in performance.
Sorry for the long winded post but I'm puzzled on this one.
Thanks!
Mike D
Tampa Fl
Old 03-15-2015, 12:23 PM
57 views and no thoughts
Ok, here's some more info...
I drained the entire tank and added 10 gallons of super unleaded. I also added a can of Seafoam to the tank. I then drove it around for about 20 miles in varying conditions.
The only noticeable issue after 15 miles was a little stumble off 2000 rpms. Sounds a little like vapor lock to me. It's about 80-85 here in Tampa in the shade. I did have an issue last year but added a 1/2 inch phenolic spacer that seemed to clear things up.
Nothing has been changed leaded to this issue.
Dirt in carb? Vapor lock? Mallory dist failing?
Blue66 likes this.
Mike D
Tampa Fl
Old 03-15-2015, 12:40 PM
PeteF's Avatar
Sounds like bad fuel (you mentioned a bad smell), or contamination in the fuel bowls. I assume you have a good filter installed. The only things I could recommend now is to spray some Seafoam through the air bleeds of the carb, and/or pull the front bowl and look for debris. Good luck.
Old 03-15-2015, 01:09 PM
Cobra Make, Engine: FFR fat block tko 600 9"
By your description sounds like fuel boiling in float bowls. Mine did that sometimes on hot days. Fixed mine by accident when I added a turkey pan. Carb stays nice and cool on hot days now. Next time it happens put your ear near carb, if quiet enough outside you'll be able to hear it if that's what is happening.
Old 03-15-2015, 02:17 PM
Both thoughts crossed my mind. I appreciate the ideas.
The fuel boiling issue was bad last year and it seamed as though the 1/2" spacer fixed it. Maybe a combination of some bad fuel and boiling.
I'll keep searching.
Mike D
Tampa Fl
Old 03-15-2015, 03:15 PM
Gaz64's Avatar
I'd be checking the needle and seats for fuel line debris, then pull the float bowls to see if any rubber debris has made it's way into the metering blocks.
How much rubber line after the fuel filter?
How old is the rubber and when did you last "service" the rubber? ie: change fuel filter or replace a hose?
Old 03-15-2015, 04:37 PM
Cobra Make, Engine: BDR#1344/Dart SBF 427
I was going to say dirt in the needle and seat also. Will flood the front primary and kill the car. Had this issue with a QF 750. Had the same symptoms as you.
Old 03-15-2015, 04:38 PM
Are you saying that the tach goes to zero with the car in gear? If that's the case, you are having an intermittent ignition failure.
Old 03-15-2015, 07:28 PM
Thanks to everyone for the responses!
The car was completed in June of last year. The entire fuel system is brand new. Fuel pump, fuel filter, steel line up to the firewall then back to a 3/8" fuel line to the new regulator then a small piece to the carb, which is also brand new.
The car has 1600 miles on it already. In Florida I try to take it out once a week. The 1/2" spacer helped last year but this just seemed to have just come out of nowhere. I did look at the sight glass on the front and rear of the carb and the floats seem high. I never adjusted them when I pulled it from the box but maybe I can drop them a little to see if that helps.
I'll also get in there after that and clean the needle and seat.
I mentioned the tach going to zero but I may have had the clutch in pumping the gas, I can't remember for sure. I haven't ruled out the ignition problem yet.
Mike D
Tampa Fl
Old 03-15-2015, 07:41 PM
Dwight's Avatar
Smile
check you fuel filter for size and does it have any trash (bits of rubber from the fuel line)in it?
Ethanol gasoline eats up most rubber.
Dwight
Old 03-16-2015, 01:26 AM
Cobra Make, Engine: Shamrock
Perhaps you have an intermittent electrical issue further up the line such as battery earth - did your other electrical gauges die at the same time as the rev counter.
The above wouldn't explain the symptom of lowered power at times.
Old 03-16-2015, 04:40 AM
Gaz64's Avatar
This is your first problem, and needs to be addressed asap.
ALL carburettors need to have their float level checked and adjusted, especially removed from a box and fitted for the first time.
It has gone through transportation with the floats banged around upside down etc.
QFTs are great carbs, and I'm SURE the carb would come with instructions to tell you to set the levels correctly prior to engine start.
Old 03-16-2015, 04:47 AM
Ron61's Avatar
Post
I had much the same type of issue with one of my cars several years ago and it took months to finally find it. I thought it was a fuel problem and we check and cleaned the carb, fuel lines, and everything looked and tested OK. Then one day when we had it on my friends lift at his garage and it was at idle he noticed the rubber hose that connected to the fuel line suddenly sucked closed. We had checked that hose several times and it felt good. But it would start to close a little and power would drop and suddenly the engine would die. We pulled the hose off and checked it, even cut it open and it looked good. No soft spots or anything. But I put a new hose on and have never had a problem since. And as coincidence would have it a month or so after that a guy that I worked with was talking about his Dodge Charger doing the same thing. He had spend quite a bit having garages look at it and I told him what I had found. He changed that short rubber line and his problem went away too. And the one he took off looked good and had no soft spots in it either.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-16-2015, 07:13 AM
Thanks again for the help everyone. Sounds like with some time this may be an inexpensive fix. I'll start by replacing the rubber hose and fuel filter (it's a canister type so I won't be able to inspect it easily).
As far as the carb adjustments, I'm going to get that sorted at as well. I expected some adjustment would be needed but it ran absolutely perfect for 1600 miles in varying conditions, extreme heat and what Florida considers low, maybe 35.
I'll also watch for changes in gauge movement when it acts up in case it's an electrical issue. Unfortunately I'm usually looking for a safe place to quickly exit the road when it starts to fail.
I'll keep everyone posted. And again, this is what makes the site great. Everyone sharing the unique examples of what can go wrong and the fixes you've found.
Mike D
Tampa Fl
Old 03-17-2015, 11:08 AM
Update...
I found a slight kink in the 3/8" fuel hose between the electric fuel pump and the canister filter. I'm removing the filter between the tank and pump all together and replacing the fuel line as well as rerouting it to provide more of a straight shot.
I'm adding a 40 micron filter just before the fuel regulator to provide filtering. The one I purchased seems ok but is only rated for 300hp. I suspect I'm closer to 375. That being the case, it's only street driven so is it safe to assume that the fuel in the bowl would buffer any starvation issues?
http://www.summitracing.com/parts/rus-645150
Once finished it'll be tank-fuel pump-40 micron filter-regulator-carb.
Sound ok?
Many thanks to all who have responded!
Mike D
Tampa Fl
