Like Tree3Likes
  • 1 Post By Detroit Bill
  • 1 Post By rodneym
Old 04-21-2015, 06:52 AM
Cobra Make, Engine: Superformance #3168
Default Tachometer problem
I have a Superformance Cobra with 3000 miles and the tachometer stopped working. Can anyone recommend a quick fix?
Old 04-21-2015, 07:14 AM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Not without seeing the car, no. It's either a drive gear issue or a guage issue. First thing I'd do is check the drive end at the transmission, could be loose. If not, unscrew it and lightly chuck the cable end in an electric drill and spin it. If the needle moves its the transmission fitting, likely the drive gear. make sure everything is tight first, you can reach up behind the dash and finger tighten the knurled lock ring on the guage .
The older I get, the faster I was.
Old 04-21-2015, 10:18 AM
I'm not sure where SPF gets their gauges, but you might give Nisonger a call. Your tach may be repairable.
Nisonger Instruments :: the exclusive Smiths U.S. Warranty & Service Center since 1949
Old 04-21-2015, 11:38 AM
He said Tachometer not speedo.
cycleguy55 likes this.
Bill
Old 04-21-2015, 11:40 AM
A good place to start would be checking the wires on the back of the Tach, have you done that?
Bill
Old 04-21-2015, 11:56 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
In my old SPF I had a tach issue that was cause by the center contact in the dizzy being dirty.
Blas to the rescue.
CompClassics likes this.
rodneym
Old 04-21-2015, 12:34 PM
Sailfish's Avatar
Cobra Make, Engine: Superformance #2144 with a Roush 342R (sold June 2018, but still lurking on Club Cobra)
I had an issue in my SPF with the tach being erratic. Turned out to be a bad battery to chassis ground (ground wire was just barely attached to the chassis). I cleaned and refastened the ground and the tach immediately worked as it was supposed to.
Old 04-22-2015, 07:53 AM
Tim7139's Avatar
DUH, why yes he did.
Old 04-22-2015, 07:54 AM
But we love the enthusiasm with which you jumped in to help!
Bill
Old 04-22-2015, 07:57 AM
I think when I get my car I am going to make sure that ground is good and possibly add and or check the engine to chassis ground. That is a classic cause for mystery problems. Stand on the gas and the car stumbles.....
Bill
Old 04-22-2015, 08:16 AM
Tim7139's Avatar
Remember, all these Smith's tachs were mechanical, I guess I'm in motorcycle mode, my Triumph's have nice cables off the gearbox.
Old 04-22-2015, 08:54 AM
Senile Club Cobra Member
Roger,
Give me a call. We will ship a replacement if needed.
rick@autoventureusa.net
Tags
tach, tachometer
