| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
3Likes
Post By Detroit Bill
Post By rodneym
04-21-2015, 07:52 AM
Tn
Cobra Make, Engine: Superformance #3168
Tachometer problem
I have a Superformance Cobra with 3000 miles and the tachometer stopped working. Can anyone recommend a quick fix?
04-21-2015, 08:14 AM
Ny
Cobra Make, Engine: Superformance #2660, FE-406
Not without seeing the car, no. It's either a drive gear issue or a guage issue. First thing I'd do is check the drive end at the transmission, could be loose. If not, unscrew it and lightly chuck the cable end in an electric drill and spin it. If the needle moves its the transmission fitting, likely the drive gear. make sure everything is tight first, you can reach up behind the dash and finger tighten the knurled lock ring on the guage .
The older I get, the faster I was.
04-21-2015, 12:38 PM
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
He said Tachometer not speedo.
Bill
04-21-2015, 12:40 PM
A good place to start would be checking the wires on the back of the Tach, have you done that?
Bill
04-21-2015, 12:56 PM
Full Blown Member
In my old SPF I had a tach issue that was cause by the center contact in the dizzy being dirty.
Blas to the rescue.
rodneym
04-21-2015, 01:34 PM
FL
Cobra Make, Engine: Superformance #2144 with a Roush 342R (sold June 2018, but still lurking on Club Cobra)
I had an issue in my SPF with the tach being erratic. Turned out to be a bad battery to chassis ground (ground wire was just barely attached to the chassis). I cleaned and refastened the ground and the tach immediately worked as it was supposed to.
04-22-2015, 08:53 AM
Ny
DUH, why yes he did.
04-22-2015, 08:54 AM
But we love the enthusiasm with which you jumped in to help!
Bill
04-22-2015, 08:57 AM
I think when I get my car I am going to make sure that ground is good and possibly add and or check the engine to chassis ground. That is a classic cause for mystery problems. Stand on the gas and the car stumbles.....
Bill
04-22-2015, 09:16 AM
Ny
Remember, all these Smith's tachs were mechanical, I guess I'm in motorcycle mode, my Triumph's have nice cables off the gearbox.
04-22-2015, 09:54 AM
Senile Club Cobra Member
NY
Roger,
Give me a call. We will ship a replacement if needed.
rick@autoventureusa.net
