Like Tree5Likes
Old 08-08-2015, 05:07 PM
Cobra Chris's Avatar
Cobra Make, Engine: FFR
Default Oil Puke Tank
In looking for an oil puke tank, I ran across this old gas tank that looked similar... It is 6 14/16" long and 3 1/2" in diameter...Is that the correct size? If not, is anyone reproducing them? Looks like Nick Acton no longer has them in stock?
Thanks!
Chris
Old 08-08-2015, 09:09 PM
DWRAT's Avatar
What's a oil puke tank for?
Does your motor kick out oil?
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 08-08-2015, 09:25 PM
They were mounted on the firewall and conected to the engine manifold and transmission...They condensed oil vapors and drained them back into the pan.
Old 08-08-2015, 09:39 PM
DWRAT's Avatar
Do you need a puke tank anymore with a pcv?
FFR MK1---Sold
No more Furds.
Old 08-08-2015, 11:24 PM
LMH's Avatar
LMH LMH is offline
Nick is probably temporarily out of stock. Kirkham used to sell them as well, so you might want to check with them if you don't want to wait.
Alba gu brąth
Old 08-09-2015, 02:43 AM
Jamo's Avatar
Super Moderator
Before PCVs, venting was provided by the oil vapor tank, commonly called a puke tank (a puke tank is also what you set up to catch overflow from your cooling system, especially at the track). The vapors were drawn out by a road draft tube (runs down to hang down into the airflow near the starter)...the remaining oil would drain down to the pan. Old grey beards like myself will recall the oil stain that ran down the middle of the lanes on a road before PCVs returned the vapors to the engine to be burned up. Old school...and it works perfectly (and has for the dozen years I've run the tin can on the track and on long cruises). Mine was set up by the boys from Provo to be as original as possible. I do not run a PCV...I prefer to leave my stain on the road. I also like to run gas through my engine, which is not a diesel.
Here's a simplistic drawing...mine also has a tube connected from the rearend and transmission (via a "T") going into the tank via another fitting next to the one from the engine to draw the wet vapors from those sources as well.
Here's a pic of the road draft tube fitting/hose and the oil tube running down to the pan.
Here's the intake side of the tank...the tube connection on the right hand side is the one coming from the rearend and transmission.
As we like to say at Gasholes...hope this helps with your build.
Jamo
Old 08-09-2015, 02:47 AM
Jamo's Avatar
Super Moderator
No. But then again, you might as well buy a Corvette.
Jamo
Old 08-09-2015, 03:32 AM
Jamo's Avatar
Super Moderator
Cobra Chris...resized your pic for you.
albanycobra and LMH like this.
Jamo
Old 08-09-2015, 07:56 AM
LMH's Avatar
LMH LMH is offline
Yes, original tanks were modified lawn mower tanks. The one you have pictured looks like the right one but IMO, building one isn't as easy as it looks. You're better off buying one built.
Alba gu brąth
Old 08-09-2015, 03:40 PM
1985 CCX's Avatar
Try Racewhere.
John will be a great source.
KMS as well if they have one.
I would convert your tank. My two cents.
Old 08-09-2015, 06:12 PM
mickmate's Avatar
Originals used an old gas tank very similar to that. It was about that length with a 4-3/16" diameter. I had a box of the originals I converted to puke tanks that are all gone. I do have a couple in stock that I grab whenever I find them. There is also a modern repop I supply and I'm waiting on the next batch. I make the beaded tubes for them and silicon bronze them together with the TIG. You should convert that treasure in to one. Let me know if I can help with parts or converting it. Word to the wise, don't bake it to clean it or powdercoat it, the solder on the cap flange and centre seam runs out.
mickmate
http://www.actoncustom.com/
Old 08-09-2015, 06:16 PM
mickmate's Avatar
Some helpful pics of configuration here. PhotoPost Classifieds - Puke Tank Cobra 427 Shelby Comp SC Oil Tank - Powered by PhotoPost Classifieds
mickmate
Old 08-17-2015, 03:03 PM
RedCSX1's Avatar
I decided to design and construct my own and I also run a PCV valve. Made of stainless that has been polished The breather is from MOON. No oil streak left on the road.
Morgan LeBlanc
Fresno CA
Old 08-17-2015, 03:12 PM
Jamo's Avatar
Super Moderator
Obviously a heathen commie enviro-Nazi.
Jamo
Old 08-17-2015, 05:09 PM
RedCSX1's Avatar
Clearly I have been in the mountains too long! Now I have to go and stop someone from shooting a lion!
Morgan LeBlanc
Fresno CA
Old 10-17-2015, 06:47 AM
cobrakiwi's Avatar
Chris sent his tank to us for the mods needed, it turned out really nice.
Old 10-17-2015, 06:53 AM
cobrakiwi's Avatar
Chris has decided the smaller tank looked a little to small so is sending a bigger tank for the same treatment.
I have these tanks in stock if any body is looking for one.
The tank with the blue back ground is one of our new tanks.
Old 10-17-2015, 08:35 PM
Craig-
You did an amazing job...The first one is 3 1/2" in diameter and would be typically be fine but I have my firewall recessed back a few inches so it looses it's impact and visibility...Therefore I have decided to go a little larger... My new tank is approx. 4 1/4" in diameter where I believe the originals where between 4 and 4 1/4 so should suit me well...Thanks again for all your help and I look forward to other projects with you.
Chris
cobrakiwi likes this.
Old 10-22-2015, 05:08 AM
cobrakiwi's Avatar
Chris
I finished your tank up yesterday, will get it on it's way to you.
Thank you.
601HP and ScratchBuilder like this.
Old 10-22-2015, 08:41 PM
Awesome! Looks great...I just emailed you about what you thought of the tank I sent and your already done...I look forward to getting it back.
Thanks again!
Chris
