| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
1Likes
03-02-2014, 10:51 AM
CA
Thinking of an air-fuel meter to tune carb - any experience?
I recently finished my car and got it on the road. I've had a few issues, nothing major. Next up, I need to optimize the tune. Brent tuned it on a dyno, but mentioned the fuel and atmosphere could be significantly different in Kentucky (where he is) vs NoCal (where I am).
There is just one shop here of which I'm aware that tunes carbs - Ole's in Redwood City). They are supposed to be very good and work on a lot of rods, but they clearly are old-school. I think they just do it by ear and experience.
I'm thinking it may make sense for me to buy a wideband O2 meter or gauge and tackle this myself. That way I could use it on both of my carb'd cars, learn how to do this right, and make sure the car isn't running too lean or rich.
Innovate Motorsports seems to be the leader in this area, and they have handhelds and gauges (cheaper, and sort of cool to see it in real-time). But one issue I have is that I didn't weld in an O2 bung when I put the car together, so I would either have to do this (and recoat the ceramic wherever I weld it), or use their clamp on the exit of the sidepipe (probably adequate and easier).
My questions are: what do you think of tuning it myself with one of these set-ups? Any experience would be appreciated - especially whether you could get the tune right pretty easily or if air-fuel meters are a rat hole. Also, what gear have you used successfully? Thanks!
03-02-2014, 11:18 AM
Oh
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
I've had good with my LM-1 and the tail pipe mounted clamp. I drilled and tapped the end of the probe to accept a piece of brake line. Use a 12 inch or longer piece, then you don't have to worry about reversion at the end of the pipe messing up your readings.
Jack
XSSIVE .....
03-02-2014, 11:59 AM
Cobra Make, Engine: Contemporary-427 stroker
I use a LM 1 as well. I use bungs welded into the exhaust pipe at the front of the collector. If you mount the bung towards the inside of the car there is no need to re-coat the pipe as it cannot be seen except from under the car. The LM 1 will do a much better job than an ear ever will. Well worth the money.
03-02-2014, 01:25 PM
CA
If I get the LM-2 with an exhaust clamp, I can use it on multiple cars, on both sides of the exhaust, and without removing the sidepipes to weld in a bung. Can you drive with the exhaust clamp, or only use it while parked?
03-03-2014, 04:13 PM
Cobra Make, Engine: Shell Valley
Yes, make SURE you mount it somewhere on the collector as ANY exhaust leak with throw the readings off, ask me how I know.
I've got an LM1 on a twin turbo truck, and I mounted it just after the collector as the headers were already in the truck.
Well, even with a V-band exhaust clamp I still have a very slight leak which drives the AF gauge wild. So guess what I will have to do all over again.............
You can put a chebby engine into a Ford body, but it will NEVER be a chevrolet. It also shows you're ignorant, and lack imagination, as in its been done to death as in its not an original idea.
03-03-2014, 07:55 PM
MO
Cobra Make, Engine: Hurricane - FE
Try this one
This review by Ford Muscle confirmed to me the LM-1 and LM-2 are the best choice.
Paul
03-04-2014, 10:05 PM
I feel the need for speed
I use an AEM. It mounts in the dash and reads vacuum and AF ratio. It data logs 3 hours of data and plugs into your computer so you can down load and evaluate the data. I have dual quada and it has helped a lot getting things dialed in.
Mike
03-02-2014, 01:30 PM
CA
Cobra Make, Engine: SPF #1019
Henry "Ole" Olson uses a 5 gas analyzer, as well as an LM-2. He wrote this a few years ago: tuning performance You should go talk to him if you are local to the Bay Area (San Bruno)...
03-02-2014, 07:18 PM
CA
I'll check him out, thanks. But I still may get an analyzer.
03-02-2014, 01:36 PM
Oh
I drive with it....shut the door on the wire and go. The first one I didn't shut the door on the wire and let it hang over the door...well the clamp came lose and and dragging on the ground..... had to get new O2 sensor and clamp.
Jack
XSSIVE .....
03-02-2014, 02:06 PM
Ut
Cobra Make, Engine: 66 Cobra
I did a thread on installing a wideband O2 sensor. O2 Sensor Install
Last fall I bought the Innovate MTX-L wideband and love it. I am not installing it in my dash, just using it as a tool. I then will put the plug in the bung. I installed the O2 and did some tuning last fall just as it was getting cold here in Utah, so I will finish it this month.
I'm an old guy and have worked on most carbs in the 60s and 70s. The wideband is wonderful. No more reading plugs and guessing. With the one I have I can hook it to a laptop and see the AF graph as you drive or just watch the gauge. You can watch each circuit; idle, transfer, main metering, power, accelerator pump, and secondaries on the graph. Just pay attention to how you are operating the throttle. You can record I believe about 50 minutes of running and save the file, then make your changes and run it again. Then compare to the previous file.
I found that recommended jet changes for altitude by the carb manufacturer was way off. With the second jet change I am running from 14.5-15 for main metering. I still have a lot of playing to do. This is one of the funnest tools I have ever bought.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
03-02-2014, 07:35 PM
VIC
a couple of years ago i purchased a kit from 14Point7.com to make my own wideband sensor - premade/retail was very expensive at the time.
Amazingly it worked (?!)
If you're going down this path I suggest a walk around the web-site becasue the products seem to keep growing & improving
LoBelly
03-03-2014, 03:40 AM
Me
I started down this same road have the gauge just need the O2 sensor. Also been a carb tuner all my adult life and have it down pat which made me realize it takes me no time to get the carbs working as good as they are ever going to. The plugs and seat of the pants is my gauge.
Good Luck in your quest.
03-03-2014, 06:28 AM
Oh
Here's an excellent article of plug reading and timing.
Spark plug reading
Jack
XSSIVE .....
03-03-2014, 07:34 AM
Ut
Wayne
Gil Younger
03-03-2014, 01:53 PM
CA
Did a little more work on this and spoke with Innovate tech support. They recommend an LM-2, which has data logging capabilities. Also said to weld in the bung, and not to use the clamp (readings will not be nearly as good). I'm almost sold, but reading through some reviews it seems the quality and reliability of the LM-2 is pretty weak. Anyone have recent experience? They could've fixed initial quality problems.
03-03-2014, 02:41 PM
PA
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
All you need is a 02 & a volt meter shoot for 0.3 volts.
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
03-03-2014, 05:56 PM
Junior Member
CA
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
I use a Lm1 on a race truck at Bonneville and it works great! After each run we can choose to or not to make an adjustment on the fuel injection. We have 3 records in 3 years. I have a LM2 on the cobra and it worked great until the # 2 sensor plug broke off the LM2 unit. It's under warranty, they fixed it and it's in the mail right now. The first time I hooked it up it read 11.5 on the left bank and 13 on the right bank. So I'm working on that problem now. It's a wonderful tool. I will keep using them.
Tom
03-03-2014, 07:20 PM
CA
This one doesn't have data logging, but it's supposed to be the most accurate and durable. NGK Performance Products - Powerdex AFX™. I would tune (1) idle, (2) cruise, (3) WOT, and (4) transition to WOT. So do I really need logging?
03-03-2014, 08:47 PM
Junior Member
CA
I don't use data loging with the cobra. Watch it real time. Although it's hard to do that at wot. I put bungs in the pipes when I built the headers. Use blue tape to hold the wires on the body to the cockpit. I drive the car 30 to 45 minutes to get it completely warm. It makes a difference in the readings.
Tom
