1Likes
12-12-2015, 09:01 AM
Oh
New Ford flat plane crank engine
12-12-2015, 09:43 AM
I would really like to have one of the new GT-350 Mustangs. There is one of the street versions here and it really is nice and sounds great.
12-12-2015, 10:21 AM
WI
I really like what I've been reading and hearing about this engine. I think it would be a better fit in a light sports car like a Cobra than the heavy big block luggers that we're accustomed to. Suddenly I'm daydreaming about a nice, accurate-looking replica with modern suspension and brakes and one of these revving, wailing engines providing the music and the motivation. hmmm...
Tropical Buzz
12-12-2015, 02:19 PM
SA
Originally Posted by Buzz
....Suddenly I'm daydreaming about a nice, accurate-looking replica with modern suspension and brakes...
Buzz, something like this maybe?
Glen
12-12-2015, 03:18 PM
WI
Absolutely Glen! The Pace chassis is exactly what I was thinking of. And now that you mention it that flat plane revver would really be at home in an FIA replica. I've been following your build - can't wait to see the finished body.
Tropical Buzz
12-12-2015, 05:45 PM
SA
Ha ha.....even with that super chassis (oops, semi-monocoque) I'm still going traditional with the engine. For me it has to be an SBF with a Toploader behind it.
No doubt about it though, that flat plane crank engine will be one of the great engines, for sure.
Glen
12-16-2015, 06:49 AM
Oh
So, if the flat plane crank shaft is easier/cheaper to manufacture, allows more RPM, better breathing, thus more power, then why hasn't racing teams been dropping flat plane cranks in every block ever raced? Why don't I see advertisements for a flat plane crank and matching cam for every push-rod V-8 ever made?
Until now I never heard of the term flat plane crank. I thought I was well read, but obviously not nearly as much as I arrogantly thought. Anyone else caught off guard on this?
12-16-2015, 07:16 AM
From what I have read and seen on videos the Flat Plane Crank engines are more race oriented and have some balance issues which will cause them to not last as long in regular use. You Tube has a few good videos on them with people explaining the differences and what to expect. They rev faster because of less weight.
12-16-2015, 08:30 AM
NV
Most FPC engines (and they've been around for a long time even in consumer applications) are small displacement. FPC has dynamic balancing issue that increase with displacement. Voodoo is the largest FPC engine so far. There are many "warts" to keep it from vibrating. Some are on the engine, some are external to the engine. Look at photos of the underside of the GT350 and you will see weights on the exhaust aft of the catalytic converters.
The FPC also sacrifices low end torque for higher RPM operation. That's good for a track car.
Early articles in trade magazines (ASE) indicated it was unlikely that a FPC crate engine would be available.
However, Ford announced a few weeks ago the Voodoo parts (block, heads, etc) to build an engine using the standard 5.0 Coyote crankshaft, and that engine showed up as a crate engine in the past week or so. More info:
http://www.stangtv.com/features/pri-...e-engine-a52xs
CSX4005LA
12-16-2015, 09:30 AM
I remember seeing a small block Chevy have a flat plane crank close to 30 years ago. It was a racing engine with a Hilborn fuel injection. They were setting it up for a dyno run at a shop near where I lived.
12-16-2015, 09:43 AM
NV
On the FPC "invention". it really isn't new, only newly hyped. However, this minimizes the amount of invention that Ford had to do to get a FPC working in such a large displacement engine.
https://www.linkedin.com/pulse/flat-...kim?_mSplash=1
CSX4005LA
12-16-2015, 11:43 AM
CO
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
But I'll bet you've heard the term "odd-fire", right?
It's the same thing. Flat plane just sounds so much better than odd-fire. That and those that know odd-fires hate 'em because they are so unbalanced they'll shake your teeth out.
Odd-fire V-6's were real popular in GM cars. The 3.8L Buick engines were odd-fire engines. Although IIRC, they also made a even fire 3.8L.
Phill
12-17-2015, 04:30 AM
Phill
An odd fire V6 is not the same as a flat plane crank if that is what you are stating. An odd fire resulted from basically removing 2 of the cylinders off a V8 giving the engine an unbalanced firing order in regards to crank timing. In the Buick V6, they used a split crank to break up the crank timing by 15 degrees.
12-17-2015, 10:10 AM
Oh
The FPC in and of itself does not give up low end torque, but in a conventional pushrod engine the duration required to take advantage of the higher rpm would give up low end torque. However this is a 32 valve, variable cam timing engine.
The modular engine was able to turn a lot of rpm with moderate duration, without variable valve timing. The 4 valve per cylinder head design flows very well. They also put a butterfly on one intake port of each cylinder that was closed at lower rpm. This gives higher velocity at low rpm, which keeps the torque up at lower rpm.
This engine has all the knowledge of the modular development plus the new variable cam technology and some more tricks, I'm sure I have no idea of. From what I have read the torque curve is fairly flat, but I have not seen any dyno data.
I suppose the lighter crankshaft gives up inertia, so you may notice it is easier to stall if you let the clutch out too quick without stepping on the loud peddle.
12-17-2015, 02:54 PM
SI
The 'new' Ford flat plane crank uses a lot of counterweight and places the rod journals in a one up/one down fashion along the length of the crank compared to Ferrari and others that have used- one up, two down, one up,- like a large inline four.
EDIT: with some help from people with more info than me I think I worked out the firing order for this engine, see attached dwg.
Jac Mac
12-19-2015, 08:08 AM
I have seen dyno graphs, and low end torque is a major disappointment. I have also seen dyno results of Coyote engines with old old school manifold/head changes that resulted in both better HP (at lower rpm's) and torque ( throughout the range).
And, the large-displacement FPC, DOHC, Ford engine is not new...they made an 1,100 cu inch tank engine back in the day.
It's all a marketing ploy, literally sound effects.
12-19-2015, 05:35 PM
OH
Cobra Make, Engine: Superformance, Roush 402R and CSX 6029
One of the new GT 350's was brought to a local car show this summer (by a Ford exec) and it was very impressive. A couple of things though. It did leak oil from an oil filter that had vibrated loose. Also, the specs were 525 hp and 400 ft/lbs torque. My stroked 351W is rated at 515 hp and 500 ft/lbs torque. My engine obviously will not do 8000+ rpm's but how would it do in a 1/4 mile drag race against the GT 350? Would it be close or will I be eating GT 350 dust? Just curious.
12-20-2015, 07:52 AM
Oh
The OEMs are required to do their dyno numbers with the air filter on, the exhaust connected, and the belts driving everything.... that is dyno it as it will be installed. That change happen in the early 1970s and all engines dropped at least 100 Hp that year. Engine builders are not required to do this and none of them do, as far as I know. Not to mention many play little tricks to make the numbers look better than they actually are.
That said your engine verses the GT 350 in identical cars, I would bet the GT 350 would eat you alive.
12-20-2015, 08:04 AM
Oh
http://cdn.speednik.com/files/2015/1...2_16-26-27.jpg
Here is the dyno. I do not think 300 lb-ft at 2000 rpm is all that bad. Granted that is 142 less than the peak, so it is far from flat. However from 3000 rpm up it is fairly flat. Most builders will not dyno down to 2000 rpm and you rarely see those numbers.
PS: This is from an article Twobjshelbys provided the link to above. I believe this was an independent test, not Ford data. Also note that it stated headers were used. Likely no belts.
Reason: PS:
12-20-2015, 10:11 AM
SI
Given your 351w is actually a 402 is that a fair comparison? It will be interesting to watch the aftermarket if not Ford when the poke & stroke crowd try to enlarge the cu in of the new engine, bore with light rods & pistons yes, but stroking by large amounts is going to cause some head scratching!
Jac Mac
