Old 05-08-2016, 03:30 PM
Cobra Make, Engine: Unique
Default C6 tranny issue
I have a C6 coupled to a 428 and it does not down shift (passing gear) when I hit the throttle. What are some possible causes/symptoms and cures for this?
Old 05-08-2016, 06:44 PM
Jac Mac's Avatar
Do you have a kick-down linkage/cable fitted?
Jac Mac
Old 05-09-2016, 06:26 AM
Cobra Make, Engine: Shamrock
Is the vacuum modulator connected to the inlet manifold and if so is the pipe not being sucked closed by vacuum?
Old 05-09-2016, 09:15 AM
Cobra Make, Engine: FFR fat block tko 600 9"
Actually the vacuum modulator loss or no vacuum signal would cause maximum RPM upshifts in each gear regardless of throttle setting, kinda the opposite condition...
If aliens are so smart, why do they always choose to talk to guys named Bubba?
Old 05-09-2016, 08:10 PM
Registered User
Has the car been sitting for very long or is it driven regularly? It sounds like the governor may be stuck. usually from sitting for long periods in humid climates. I would try a couple of forced manual up shifts and down shifts. moderate to heavy throttle on the up shift. the forced downshifts will force the valve closed.
Old 05-10-2016, 08:00 PM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Is this a new problem with an existing transmission that worked fine before, or is it a new transmission that you just installed?
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 05-11-2016, 05:45 AM
Thanks for all the input. I hope to find time this week to explore all the ideas suggested. To answer some questions, I just purchased the car. I immediately had the motor pulled for a freshen up, and to fix some small issues. I don't remember if the kick-down worked before and no, it had not been sitting. I wasn't around when it was reassembled so I will have to wait until I have time this week to really look at everything. Again, I do appreciate all the input. It has been a looooong time since I owned a Ford product and the memory is lacking
Old 05-11-2016, 06:52 PM
Gaz64's Avatar
What carburetor do you have, and is the kickdown linkage connected?
You need to get it sorted, before you'll be pulling the trans out from failure.
