1Likes
05-21-2016, 01:14 PM
Cobra Make, Engine: Backdraft, LS3
It sounds like you have great cars so if its going to be a hassle, screw it. I have two garages and it wasnt worth the money or hassle to do the second garage, i was going to epoxy it myself but it wasnt worth the hassle of moving everything etc etc. My garage floor doesnt get anywhere the attention from people as my toys do. If i were to do it over i think i would of spent the money elsewhere.
05-21-2016, 01:19 PM
Senior CC Premier Member
Originally Posted by RodKnock
They are a good product. The problem (I'm guessing) is that Dan would be buying 4 of them, leaving the ERA in one and then being stuck with them when he's done.
05-21-2016, 01:20 PM
Originally Posted by DanEC
Sure hear a lot of stories of peeling epoxy though - even from pro-jobs.
That's why I painted with the concrete floor enamel. It's easy to put on, easy to touch up, and requires very little skill and very little maintenance. If you stain it, or gouge it, just paint over it and it blends right in.
05-21-2016, 01:42 PM
Dan,
How old is your slab? Is it cracking much? All concrete cracks, but full curing time is important.
If there is no moisture, then maybe another option is industrial sheet vinyl flooring. It comes in big rolls and the seams are welded with a special process so you end up with a seamless floor.
Goes down in a garage like yours in a day. The only issue is that if you have any moisture in the slab and you have the vapor barrier below, it only has to one way to go. Most installers will do a moisture check first.
Hey! Im just trying to find every option!!
Vinyl Sheet Commercial Flooring by Armstrong
05-21-2016, 02:07 PM
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
05-21-2016, 02:12 PM
Originally Posted by streetrod1927
no pic
05-21-2016, 02:14 PM
I used tiles I purchased from Garage Flooring LLC. Justin, the owner was easy to work with and I got a good price. I have used my quick jacks to move my cobra and my son's Mustang Cobra. No problems. //http://www.clubcobra.com/forums/picture.php?albumid=192
05-21-2016, 02:31 PM
Tx
Cobra Make, Engine: CMC #437, 408ci
I'm thinking the floor looks fine, as is.
Scott
05-21-2016, 02:34 PM
Well that settles it then.
05-21-2016, 02:39 PM
Only a builder/contractor would say that. An owner/user wouldn't.
05-21-2016, 02:41 PM
Dan must have a friend or two who could also store a car or two. First world problems huh?
05-21-2016, 02:49 PM
I am the former, obviously. But it is a fact. Just trying to provide all I have learned over the years.
05-21-2016, 04:44 PM
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
I originally painted my garage floor. It was a new garage and I waited the recommended time before painting it. We poured the floor extra thick and so I don't think I waited long enough for it to fully cure. It was such a mess that I thought the only way to fix it was to cover it up. I used racedeck diamond plate and have been fairly happy with it. I have black and white tiles and as someone else has pointed out the white tiles get stained. I had to weld pads on the bottom of jack stands but have not had a problem with floor jacks. The tiles will also buckle a bit as they expand under direct sunlight. They go back down as soon as they cool.
05-21-2016, 05:04 PM
New concrete can expel moisture for months, especially if you have a vapor barrier under it. There is a simple test they use with small clear plastic cup that they seal over the concrete and let it sit for a while. If the cup has condensation in it, you are still "bleeding".
My 2 c
05-21-2016, 08:21 PM
Tx
I thought so.
Scott
05-21-2016, 09:45 PM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
My sister uses those mats in her horse stalls up in WA and says they are durable as hell. Never thought of them in a garage. Just wonder how dense it is and if the caster wheels will want to dig in. Maybe buy one piece and put it to the test?
I am waiting for permits to build my new 1,000 s.f. garage and looking at all floor options as well. I will be going with either polished concrete or terrazzo. With the terrazo, I can cove it up the walls about 6" and have a floor that I could literally steam clean if I ever needed to.
A word of caution on the terrazzo. I have it in about 2,000 square feet in our home and it is not impervious to staining. Anything acidic, dog pee, stomach acid or anything acidic for that matter will etch it. The only way to get rid of it is to have it repolished and it is a true PITA. It will also crack and replacement is a real chore. I don't know how it would stand up in a garage environment.
I would think the polished concrete would be a better solution and much less costly. But remember there are two types of concrete; one that has cracks and the other one that is going to crack.😛😛
05-22-2016, 08:50 AM
Oh
Does the racedeck impact acoustics, as in deaden sound and stop echoes?
I have a finished 36 x 50 garage. Every year at Christmas time I clean it up for a couple parties of ~ 50 people. Noise is an issue with a bare concrete floor. I could carpet it, but that would defeat the easy clean up when kids spill things.
Also would cleaning the racedeck with a power washer:
be safe on the racedeck?
dry in a reasonable time?
be clean enough to eat in the room?
05-22-2016, 10:24 AM
RaceDeck has a reputation for being sort of clackety when walking on it. They recommend putting down something like landscape fabric or Tyvek to dampen it but you would need to find someone who has done this to find out how effective it is. Powerwashing would not hurt it I'm certain. It has channels underneath to allow water to drain and water vapor to escape but I suspect drying would be a lengthy process - especially if your floor is fairly flat and not sloped to drain. I probably wouldn't do it.
