Like Tree2Likes
  • 1 Post By Tommy
  • 1 Post By Cobra Chris
Old 11-13-2016, 06:52 AM
Bill D's Avatar
Default Need Some Guidance With Master Cylinder Sizes
Front brakes: 94 Mustang GT
Rear brakes: 94 Mustang Cobra
Pedals: Wilwood floor mount 6:1 ratio
From what I can determine with the information available, which isn't much, I come up with 5/8 bore for the front and 3/4 for the rear.
Any help is greatly appreciated
Bill
Old 11-13-2016, 03:06 PM
Cobra Make, Engine: B&B
Can you use 94 Mustang master cylinder if not find bore size of it and get one the same bore size.
Hope that helps
Old 11-13-2016, 03:26 PM
Bill D's Avatar
I have dual master cylinders. That won't work
Old 11-13-2016, 03:47 PM
Tommy's Avatar
Bill D,
If no one with the exact setup you have comes by, perhaps this website can give you some insight: Brake Calculator
Eventually you will have to decide what combination of pedal pressure and pedal travel feels best to you. A smaller diameter master cylinder will reduce the amount of pressure you have to apply, but the pedal will have to travel farther to push enough fluid to move the calipers sufficiently. So in your case, you'd use the calculator to enter the fixed data (e.g., caliper diameter and pedal ratio), add the pedal pressure / travel you'd like and see what master cylinder diameter is required.
Bill D likes this.
Tommy
Previously owned EM Cobra
Old 11-13-2016, 04:53 PM
Pose this question to the guys over at the FFR forum. They're more used to dealing with pedal geometry and bore sizing.
Old 11-13-2016, 05:08 PM
Bill D's Avatar
Thanks Tommy. The calculator worked great. I came up with .73 for the front and .69 for the rear. I'll use .750 for the front and .625 in the back.
Bill
Old 11-14-2016, 05:19 AM
Cobra Chris's Avatar
Bill
I used 3/4 for both front and back and then just get yourself a willwood bias adjuster...
Gaz64 likes this.
