Like Tree3Likes
  • 1 Post By LMH
  • 1 Post By map
  • 1 Post By LMH
Old 12-28-2016, 08:33 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
Default 289 Expansion Tank Bracket.
Moving along on the Allied working on the Expansion Tank does anyone have any Pix of the bracket? I have a bald top Lincoln tank the tank & brackets are Unsolder it's bracket time.
Mike
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
Old 12-28-2016, 09:28 AM
LMH's Avatar
LMH LMH is offline
We made two brackets using an original as the pattern. We cut new copper to cover the old hose fitting and attach the new fitting for the heater hose tube. The filler neck has to be rotated to reorient the overflow tube and a small tube was added in the front for the radiator expansion tube. Lots of work but it turned out well.
1985 CCX likes this.
Alba gu brąth
Old 12-28-2016, 10:17 AM
map's Avatar
map map is offline
That's what I'm looking for Thanks Larry!
6S1941
73 2.3 turbo pinto
Old 12-28-2016, 11:18 AM
LMH's Avatar
LMH LMH is offline
Here's another showing the bracket w/o the tank. Original on the left, repo on the right.
Alba gu brąth
Old 12-28-2016, 11:34 AM
1795's Avatar
Damn, you do good work Larry! A thing of beauty
Old 12-28-2016, 02:43 PM
map's Avatar
map map is offline
[quote=LMH;1412081]Here's another showing the bracket w/o the tank. Original on the left, repo on the right.
Larry[/QUOTE
Larry what's the clearance between the VC & the bottom of the tank/bracket?
Mike
6S1941
73 2.3 turbo pinto
Old 12-28-2016, 09:37 PM
LMH's Avatar
LMH LMH is offline
I'm not sure as it's not installed. We test fit it once completed to an engine with Cobra aluminum valve covers and had no fitment issues though.
Alba gu brąth
Old 12-29-2016, 04:26 AM
Senile Club Cobra Member
I have patterns for the bracket that I have shared in the past.
On my car I needed to use spacers of about 3/8" to "stand off" the tank for clearance, however I am using the "tall" aluminum valve covers as I have a roller type valve train.
rick@autoventureusa.net
Old 12-29-2016, 08:17 AM
Larry do you know where cobra restorers get there tanks?
http://www.parts123.com/parts123/yb....5Z5Z50000027b#
Mark
Old 12-29-2016, 09:24 AM
LMH's Avatar
LMH LMH is offline
I don't, sorry Mark. I know they are physically a different size than the original tanks though. Slightly more narrow if I remember correctly.
Alba gu brąth
Old 12-29-2016, 09:30 AM
Thanks Larry I don't need one but thought they looked good but did not know how exact they were .
Mark
Old 12-29-2016, 09:43 AM
LMH's Avatar
LMH LMH is offline
It's a good looking tank and I think it would work fine, I just have to do things the hard way!��
Alba gu brąth
