Old 01-11-2017, 01:37 PM
Default Engine Oil
You guys have probably talked this to death.
I have a 302, makes about 400hp. Extra size sump, dual oil filters, and oil cooler make the capacity over 9 quarts. I would like synthetic, but am concerned about viscosity for the engine and the propensity for leaks by not getting used much.
Any suggestions appreciated.
Old 01-12-2017, 04:55 PM
Most folks here use conventional oil (not synthetic), high zinc. Either Joe Gibbs, Brad Penn, or Valvoline VR-1. I use VR-1 10-30.
Old 01-31-2017, 11:46 AM
So I'm confused.
This add says VR-1 10W30 is synthetic:
[ame]https://www.amazon.com/dp/B006NT84P0/ref=psdc_15719391_t2_B00DJ4FMK2[/ame]
Other places say its standard oil. Other advertisers don't say.
It also come in 2 different containers.
So, mineral oil, semi-synthetic, or synthetic?
Crendon 427, in the making
http://crendonreplicas.com/
Old 01-31-2017, 12:33 PM
1795's Avatar
Valvoline makes both a synthetic and a standard VR1 Racing oil.
Old 01-12-2017, 05:21 PM
bobcowan's Avatar
Here's some quick reading for ya.
Engine Oil – Viscosity – Racing the Exocet
Engine Oil – Synthetic? Dino? So Confusing. – Racing the Exocet
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 01-13-2017, 09:00 AM
Engine Oil
For what it is worth:
I used plain old Castrol GTX 20-50 in my engine from 2013-2016 and according to the builder it was perfect on disassembly, the bearings could have been reused, valve guides were tight and bores were perfect. This engine was autoxed and regularly turned 8200 rpm. with very high oil temps in the summer with two drivers. When we dynoed it on synthetic we had some oil get by the rings (we think) and it detonated and blew a head gasket. I never tried synthetic again. I was very happy with the results considering how cheap and available Castrol GTX is. We used Joe Gibbs break-in oil and Joe Gibbs synthetic racing oil when the detonation occurred. Engine is 498 CID and 15 to 1 compression with a solid roller cam .800 lift. Valve springs were also unchanged as far as pressures go I would use Castrol again.
Old 01-13-2017, 09:10 AM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
I am old....I don't do track days....I roll into every shift, brake, ect... I seldom exceed 5000 rpms....I change the oil and filter every 3000 miles or driving season ....oil is oil to me...I use what ever is on sale at WalMart...
Old 01-30-2017, 05:51 PM
fordracing65's Avatar
Originally Posted by Cobra #3170 View Post
Engine Oil
Very interesting. I think the top 3 used not in any order is joe Gibbs Brad penn valvoline vr1. Does the castrol have the zinc in it???
PRIDEnJOY
Old 01-30-2017, 06:00 PM
For sale on Amazon now. The prices for a case of 12 1 quart bottles. Joe Gibbs was $104. Brad penn was $80. Valvoline vr1 was $78. I think we have an oil poll on the forum where we voted.
PRIDEnJOY
Old 01-13-2017, 04:02 PM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
Dzzp.
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
Old 01-30-2017, 12:24 PM
PHM PHM is offline
Cobra Make, Engine: Superformance #2907 with a stroked genisis 427 side oiler and dual quads
Run Klotz oil! You will not be disappointed.
