Old 06-16-2017, 10:22 AM
byronpete21's Avatar
Cobra Make, Engine: ERA 289 FIA with a 347 cu in engine
Default Is this normal
Finally took the car out for a night drive. Noticed that my dimmer switch for the dash lights got quite hot after a few minutes. I know that rheostats heat up a bit, but is it normal for it to be painfully hot to the touch?
Byron
Old 06-16-2017, 10:53 AM
Byron
No, it's not normal for it to be "painfully hot." You might want to take a quick voltage reading on your system and make sure you're within specs (around 14v, engine running above 2000rpm) and not somewhere too high. If the voltage is normal, then you can either replace the rheostat or add an in-line high-wattage resistor to lower the resistance you dial in on the knob, and thus lower the heat.
Old 06-16-2017, 11:58 AM
Cobra Make, Engine: FFR fat block tko 600 9"
Had same problem found light switch had rivited buss bar connections with high resistance at the rivits. Flooded the connections with solder using a high wattage soldering iron and heating issue was gone. It would trip the internal circuit breaker for the headlamps shutting them off! Some warmth in switch is normal, not what you describe. Took me a while to figure that one out. Pushing 60k with no repeats.
If aliens are so smart, why do they always choose to talk to guys named Bubba?
Old 06-16-2017, 03:41 PM
My usual recommendation when dealing with the dash-light dimmer switch is to connect both the wires to the same terminal side. (Most of the switches we've got have two tabs on each side.) You'll get full brightness (usually not a problem) all the time. For the last 10 years we've had to scrape up NOS switches, and their quality leaves a lot to be desired. Unfortunately, the original Lucas switches haven't been made in well over a decade, and when we can find them at all, their price is ridiculous. To add insult to injury, I test them all and reject about 1/4 of them out of the box.
Old 06-16-2017, 04:19 PM
Originally Posted by strictlypersonl View Post
For the last 10 years we've had to scrape up NOS switches, and their quality leaves a lot to be desired. Unfortunately, the original Lucas switches haven't been made in well over a decade...
That's the benefit of having a >10 year old ERA.
Old 06-16-2017, 05:57 PM
Thanks for the advice, I will take out my trusty voltmeter and start tackling the problem.
Byron
Old 06-16-2017, 10:28 PM
Gaz64's Avatar
Also consider the total wattage of your gauge illumination bulbs.
The rheostat might not be up to the task.
It shouldn't get hot whether you are using the dimmer or not.
Are you using the dimmer?
Old 06-19-2017, 01:28 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Look to see if you have a clean tight grounds. A bad ground can cause high resistance which causes heat.
SPFWiringDiagrams@Comcast.net
Old 06-27-2017, 08:58 AM
G-Pete's Avatar
Lukas?
DRB GT40 MK1 red #49- sold
SPF 2063
Old 06-27-2017, 10:41 AM
CHANMADD's Avatar
I tried a few dimmers before I found one that was substantial enough.
Old 06-27-2017, 02:36 PM
Actually, the dimmer works by running the current through resistance wiring. By "definition" there will be heat generated, possibly the equivalent sum of all the lights in the circuit.
Old 06-27-2017, 03:50 PM
Gaz64's Avatar
I know how a dimmer rheostat works.
The owner has not stated whether he is using the dimmer resistance, and more importantly what total wattage is in the instrument lighting.
Old 06-27-2017, 05:27 PM
Dwight's Avatar
Smile headlight switch
I always use two relays for my head lights.
One for low beam & one for high beam controlled by the light switch. This take the amp load off the switch. The amount of amps to turn the relay on is very small compared to the amount needed for the headlight.
Dwight
Old 06-27-2017, 07:01 PM
Thanks again for all the good advice. Have been out of the country for a few weeks so out of contact with the internet and my car for awhile. Hopefully will get to it this weekend and have some more info to share.
Best Regards,
Byron
