Old 09-14-2017, 05:17 PM
E5USMC's Avatar
Default GPM Fuel Pump for 427 FE
Just curious what GPH mechanical fuel pump a 500+HP 427 FE would require. I'm currently using Carter 6905 ( 120 GPH) pump on my 427/482 engine and I've notice under hard acceleration it can sometimes die / stumble that feels like fuel starvation. The other day while on the interstate I hade a long run to get around a handful of semi trucks and even though only around 3-3.5k rpm for that extended run it started to try and die out. When I kick on the electric pumps, it clears right up. As long as the electric pumps are on it never dies or stumbles even when under hard acceleration.
I've read good things about the Carter pump so I'm curious if maybe my mechanical pump is having issues or if I might need a higher GPH pump.
Thanks for the advice.
AKM
Old 09-15-2017, 05:08 AM
Cobra Make, Engine: jbl
I use standard mechanical fuel pumps on a couple 500+ hp engines with nary a problem. If your electric pump or filters are located upstream that could be a restriction. Mechanicals don't like to pull.
Old 09-15-2017, 05:38 AM
E5USMC's Avatar
My filters are located under the drivers seat and the electric pumps are located in the trunk. My car is plumbed with 2 separate lines, one for the electric pumps and one for the mechanical pump.
Old 09-15-2017, 02:50 PM
Gaz64's Avatar
I like that setup.
Now what size lines front to back, what carburetor, and what size needle and seats?
Gary
