Old 03-08-2018, 09:44 AM
w-lewis's Avatar
Cobra Make, Engine: Unique, 351W
Default Backfiring on deceleration
When letting off the gas, decelerating, my 351W backfires through left exhaust only. More of a popping sound and not really annoying, but just concerned I might be damaging something in the engine. Any suggestions as to how to stop it?
Old 03-08-2018, 09:47 AM
That's almost always an air leak around the collecter/primary pipes/etc. use the Acousti-Seal that is giving fits in this current thread: Removing side pipes
Old 03-08-2018, 09:56 AM
w-lewis's Avatar
Thanks Patrick
Old 03-08-2018, 10:21 AM
MOTORHEAD's Avatar
Ck for exhaust gasket leak or intake leak also. l
"When Injustice becomes Law,
Old 03-08-2018, 10:32 AM
w-lewis's Avatar
I've tightened all of the accessible exhaust manifold bolts, but unfortunately, most are very difficult to get to, even from the underside when on a lift. At this time, the issue is not bad enough to start removing manifold to check for intake leaks. At this point, I think I'll try the header to side pipe joint first.
Old 03-08-2018, 11:01 AM
Texasdoc's Avatar
Sometimes it is a lean condition. Easy to check and it is reversible. Try richening up the idle mixture just a touch. If it is a standard Holley style carb, turn all (2 or 4) idle screws counter clockwise by 1/8 of a turn. If that doesn't fix the popping on decel, put them back where they were and work on the pipes.
