Like Tree9Likes
Old 09-14-2018, 01:46 PM
Bill D's Avatar
Here is a comparison of the length
Old 09-14-2018, 01:54 PM
Bill D's Avatar
I measure both plugs
Old .940
New .787
Shorter by .153
Old 09-14-2018, 02:25 PM
1795's Avatar
Hope that it works Bill!
Old 09-14-2018, 02:50 PM
dallas_'s Avatar
possibly get a bit thicker washer too?
Old 09-14-2018, 03:08 PM
Were all the plugs mashed the same? If so its detonation.
If some were sheared to the side or twisted 20-30 deg left of or right then it could be a piston interference problem.
Since each plug is "Clocked" differently in each cylinder. (Unless your using Moroso dead soft copper indexing washers). If its interference they'd all have somewhat different damage.
To be honest unless your running a super high compression domed pistons the contact issue is pretty slim.
Last thing on interference. It should have reared its head in 10 seconds or less during your 1st fire up I'm guessing.
The FR5 plugs you removed are a good sub for the Autolite 3924.
Old 09-14-2018, 03:57 PM
Bill D's Avatar
Spdbrake, they still smooshed when I disconnected the coil and cranked the engine
Old 09-14-2018, 04:53 PM
Gaz64's Avatar
It doesn't take much of a kiss to bend plug ground straps.
The current set have been incorrect for the engine since they were fitted.
The piston tops will have some marks but should be ok.
Note, your new set have cutback ground straps, end of strap inline with centre of centre electrode.
Old 09-15-2018, 04:40 AM
Another solution is to shorten the electrodes with a Dremel and side gap the plugs. This old racer trick also places more of the spark/flame front directly toward the piston.
Old 09-15-2018, 05:04 AM
undy's Avatar
With the plug electrodes getting hit I definitely wouldn't be comfortable with the chance that it's not only the electrodes getting hit but possibly piston-to-valve clearance issues too. When the engine is run hard the PTV clearance seems to diminish somewhat. I'd pull a head and add a bit of clay on top of a piston to check the actual clearance.
Too many toys?? never!
Old 09-15-2018, 07:11 AM
Cobra Make, Engine: SPF 2473, Roush 427R
Bill, I overtightened the plugs on my Roush 427R and flattened one plug. I'm guessing that happened to you. I like the looks of your new plugs. What is the part #?
Old 09-15-2018, 09:31 AM
If all it did to the plug was push the gap closed a bit, I doubt that hurt the piston. The shorter plug should fix this issue.
What would concern me more is the valve to piston clearance. Did you take the time to put clay on the piston, mount head and rotate, then check the clearances, buy the thickness of the clay? If not, I would be really scared right now.
Had you done this with the plugs installed you would have found the problem then. I have to admit, I have no clue if the plugs were installed, when I did this. Note to self, always have the plugs installed that you plan to use, when putting clay on the piston.
Old 09-15-2018, 05:53 PM
Bill D's Avatar
NGK 4091 gapped to .032
  #33 (permalink)
Old 09-15-2018, 06:12 PM
Danr55's Avatar
Bill put the new plugs in and if they seem to fit okay run a compression check if the compression check is okay go with it.
Dan in Arizona
CCX3209
  #34 (permalink)
Old 09-16-2018, 08:48 AM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
Default Indexing Washers
I had this problem on a 327 fuel injected Chevy 2. One or two plugs had the gap closed a little and I installed indexing washers in all plugs to increase electrode clearance. That did it, but your interference might be too great. It's an easy, cheap thing to try that might solve the problem.
  #35 (permalink)
Old 09-16-2018, 06:01 PM
Bill D's Avatar
Well, the engine quit running today and I can’t get it to start. Covered the car and pushed it aside. Time to move on.
  #36 (permalink)
Old 09-16-2018, 06:42 PM
Bill, I think taking a break sometimes is the best approach. When I'm faced with a round peg VS square hole issue (aka conundrum), I find it helpful to take a walk and mull it over. Issues like these can be a real *buster especially when another item breaks and forces the troubleshooting to skeew sideways.
I'd also PM Herr Blykins while your on break as he is a true engine guru and gives sage advice.
Don't give up, you've got common sense on your side so you will win.
  #37 (permalink)
Old 09-16-2018, 06:47 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Bourbon also helps.
  #38 (permalink)
Old 09-16-2018, 10:23 PM
Gaz64's Avatar
Time to contact the engine builder now?
  #39 (permalink)
Old 09-17-2018, 09:26 AM
Danr55's Avatar
Bill, think about it. There are only three things that will keep an engine from running. Fuel spark and Air. If the car ran fine before you change the plugs you've obviously taking something loose somewhere. Go back and check all the connections at the coil and make sure that everything is hooked up correctly then try to start it. If it cranks you can still check the spark plugs to see if the electrodes are compressed.
Dan in Arizona
CCX3209
  #40 (permalink)
Old 09-18-2018, 04:00 PM
MOTORHEAD's Avatar
Bill; you left this thread after "pushing it aside" because it wouldn't start, then you start a another thread with the engine running, but you can't get the carbs synced ,but then you did and it's running great! There's a huge gap in this story,; What was the plug mashing cure ? Why wouldn't it start ?
Inquiring minds want to know !
PS if the fixes were too embarrassing to post, just say "no comment", and we'll understand!
Ted
Gaz64 and joyridin' like this.
"When Injustice becomes Law,
