Like Tree2Likes
  • 1 Post By otto
  • 1 Post By otto
Old 02-18-2019, 06:51 PM
Cobra Make, Engine: ERA 2092
Default carter fuel pump rebuild kit
Hi, does anyone know who sells fuel pump rebuild kits for the 63-65 carter X pump for the 289 hipo , any info would be great
thank you Bob
Old 02-18-2019, 07:04 PM
Cobra Make, Engine: SPO2285
Default Fuel pump
Did you try cj pony parts. I have order several things for my foxbody very pleased
Old 02-22-2019, 09:45 AM
Cornercarverfan's Avatar
Otto,
Take a look at this article dated 2001:
Carter X Fuel Pump Rebuild
The vendor listed at the bottom is:
AMK
Broken Arrow, OK 74012
(918) 455-2651
Restoration hardware - AMK Products Inc !
Perusing their website, I don't see ANYTHING regarding Carter rebuild parts, but it's worth a call?
Or if you're considering repop rebuild parts:
https://secure.cougarpartscatalog.com/carterkit.html
https://www.deadnutson.com/carter-hi...p-rebuild-kit/
Old 02-22-2019, 10:28 AM
Its under the Misc parts section.
But for later model pumps
Misc Ford Parts
From my understanding the the earlier 63-65 pumps had a screw-on filter.
https://www.ebay.com/p/Carter-X-Body...-V-8/504687482
https://www.ebay.com/itm/Carter-X-Fu...d=323572262029
Not sure if the later repack kits would work.
Old 02-22-2019, 11:32 AM
LMH's Avatar
LMH LMH is offline
Is this for a 3623S Carter X?
Alba gu brąth
Old 02-22-2019, 11:49 AM
found a supplier called then and now auto in Ma. that has types of rebuilding parts and services , yes that is is the pump # im guessing you where looking at it on ebay
Cornercarverfan likes this.
Old 02-22-2019, 12:51 PM
LMH's Avatar
LMH LMH is offline
I have one. It is the correct pump for a Cobra. The 3723S is often advertised as a Cobra pump but that’s not correct. When I rebuilt mine, I found that the later rebuild kit will work but you have to punch out a hole in one gasket that’s not there on a later model.
Sounds like you found a kit though, so you’re set.
Alba gu brąth
Old 02-22-2019, 02:38 PM
Larry, the web site is www.then-now.com if you ever need one , thanks again for the info on the pump id
regards Bob
LMH likes this.
