6Likes
Post By cycleguy55
Post By LMH
2
Post By Dan Case
Post By Dan Case
Post By CompClassics
02-23-2019, 10:03 AM
nc
Cobra Make, Engine: ERA 2092
64 Alt fan source
anyone have a source for the fan used on the 64 alt, any info would be great
thanks Bob
02-23-2019, 02:04 PM
The press-on Fan/Pulley assembly C3MF-10344-A hasn't been reproduced as far as I know. You'll have to find one used and they don't come up for sale very often.
Kind of hate to say this but I own the last one from DST, the original supplier. I bought it NOS from Mr. Mason a few years back. He said it was the last one he had.
Alba gu brąth
02-23-2019, 02:16 PM
Mason's Dearborn Steel Tube was making new replacements in the 1980s. DST would take original style and new versions to some of the SAAC conventions in the eastern part of the country. I looked at both and the price was the same if I recall correctly. I bought the original unmolested alternator from CSX2332 instead. In later years the relatively short lived website DST kept offered new fan and sheave assemblies for sale.
Assembly versions with large diameter sheaves that I know of:
1962 prototypes, more than one version
1963 Ford production
1964 production, mostly CSX2201 and later Cobras
post production service assembly with no part number stamped in
1980s re-issues
Dan Case
Reason: add detail
02-23-2019, 04:27 PM
SK
Brian
02-23-2019, 05:22 PM
1980s re-issues
He doesn't have any now, even re-issues from the 80's are gone. When I last talked to him, he said he might have one that was bent and damaged but he wasn't even sure he still had it. I asked him to let me know if he came across it as I'd like first right of refusal but I haven't heard from him. And that was a few years ago now.
Bob, seems to me, John (CompClassics) had an original fan/pulley for sale a few years ago. I don't know if he sold it or not but you might PM him and ask.
Alba gu brąth
02-23-2019, 06:55 PM
nc
thank you for all the info,just thought it would be nice to put one on if they were reasonably priced
regards Bob Peckham
02-23-2019, 11:30 PM
I think I may still have one, I will take a look when I get to the shop Monday.
02-24-2019, 02:44 AM
Senile Club Cobra Member
We have looked at doing the pulley in reproduction but honestly the numbers do not work. The cost of tooling vs. the possible selling price and time, the market leaves us with lots of pulleys and no profit. In fact I estimate it would take more than seven years to break even and that is tripling the number sold based upon the inquires we had when we talked about this a couple years back. It has taken two years to sell out the alternator plugs we made although I did have another batch run as we needed a couple.
If you can live with the smaller pulley diameter from the standard Thunderbird/Ford/Lincoln pulley they can be found more commonly and much cheaper!
rick@autoventureusa.net
02-24-2019, 09:52 AM
CH
Did I get it correctly?
C3MF-10344-A Would be the holy grail and C3SF-10300-A is a valid alternative?
Is the pully diameter the only difference between them?
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
02-24-2019, 11:49 AM
It looks that way in my Ford parts lists by model. There is a significant difference in sheave (a.k.a. pulley) diameter between the two models.
The large (not quite 4 inches) single belt sheave for high performance engine rpm ranges keeps the alternator from failing due to higher than rated revolutions per minute when the engines are run hard.
The typical two belt passenger car sheaves are relatively small in outer diameter so that low engine rpm running is turning the alternator rotor fast enough to be doing something.
Dan Case
02-24-2019, 02:24 PM
CH
Hi Dan
Many thanks for the clarification
Not directly pully related but could you please explain it for the alternator aswell?
Many thanks
02-24-2019, 02:57 PM
Hi Dan
Many thanks
The difference in sheaves is the difference in final alternator based on the models you listed.
Dan Case
02-24-2019, 05:49 PM
I have two single sheave press on pulleys with the proper fans. Both are NOS...
1) C3MF-10344-A, nearly 4” dia., hipo
2) C3SF-10344-B, 3” dia., non hipo
