Like Tree1Likes
  • 1 Post By mtrain2000
Old 06-11-2019, 02:35 PM
mtrain2000's Avatar
Cobra Make, Engine: Shell Valley
Default I gave away my dang air cleaner.
Well, I did something stupid last year.
I sold a truck project. It was setup with twin turbos, but the buyer didn't want the turbo setup so we worked out a price with a deposit, and removal of all of the turbo stuff.
One of the turbo parts was the blow through carb. I replace the carb with a carb that I had laying around.
Well, it took waaaaay longer to remove all of the turbo parts than I thought it would. So I swapped the carb on the last day, and never got to start the engine.
The day the buyer was due, I went to tune the carb, and got tons of problems. I was running out of time so I pulled the carb off of my Cobra, and put it on the truck. Well, the normal sized air cleaner wouldn't fit, so I ended up using the air cleaner off the of the Cobra.
I told the buyer I needed to get the air cleaner back before he left with the truck, but we both forgot.
Anyway, I just finished rebuilding a new Quick Fuel 750 dp carb for the 428FE in the Cobra, and got it all installed today.
I tried a conventional air cleaner today [ie 14" dia], and the hood won't close so I measured my turkey pan, and figured a 9" air cleaner would fit. I ordered a cheap "Proform" air cleaner off Ebay for only $25. Still sucks to forget something so stupid.
Lessons learned. Get a bigger deposit next time I agree to something like this, and even though I might be worn out, make SURE everything is good to go BEFORE the day of the sale.
Here is a pic of the old air cleaner setup [I have the turkey pan]
You can put a chebby engine into a Ford body, but it will NEVER be a chevrolet. It also shows you're ignorant, and lack imagination, as in its been done to death as in its not an original idea.
Old 06-11-2019, 02:44 PM
LMH's Avatar
LMH LMH is offline
Carl’s Ford Parts. I believe that have that Stelling and Hellings air cleaner.
Alba gu brąth
Old 06-11-2019, 02:56 PM
mtrain2000's Avatar
Thanks I found one on Ebay. [I just finished editing the thread]We just had a huge car show/swap meet last weekend.
I was going to try to find one there [among some other parts]. BUT, it rained every single day so I walked away empty handed.
LMH likes this.
Old 06-12-2019, 03:39 PM
I run a mrgasket 9” x2” with a k&n flow through top. The S&H while historicall
Superformance 1764
Built 427W
Aiken SC USA
Old 06-12-2019, 03:41 PM
Default Aircleaner
I run a mrgasket 9” x2” with a k&n flow through top. The S&H while historically accurate is not very good...with motor mounts set as low as possible, a trick flow single plane intake, about 3/4” of spacers it clears the scoop by 3/8” both sides...Herod guys are ALWAYS telling me the air-cleaner is too small, but with an engine rated at 535hp she did just under 460 to the tires...it works.
Steve H
Spf1764
Superformance 1764
Built 427W
Aiken SC USA
