Old 12-20-2019, 09:04 AM
hauss's Avatar
Default Rotor phase
I am still trying to wrap my head around this one. If I am using a timing light to set my timing why should the phasing matter? would not it already be phased properly ? Remember I am rotating the dizzy while setting the timing using the light.What is it that I just do not understand?
Old 12-20-2019, 02:19 PM
Download this: https://www.mpsracing.com/instructio...ringManual.pdf and turn to page 14.
Old 12-20-2019, 03:10 PM
Gaz64's Avatar
Turning a distributor with normal mechanical advance, (with or without vacuum advance) is not normally a concern for rotor phasing.
BUT it is a VERY BIG concern if the distributor has been locked out, and you are using external electronic timing.
Old 12-20-2019, 04:39 PM
Probably the most reassuring sentence on page 14 is MSD magnetic pickup distributors are set at the factory and should not require adjusting. Come to think of it, I don't think I've actually seen an out-of-phase MSD magnetic pickup distributor. Read about them from time to time, but never actually seen one.
Old 12-21-2019, 08:44 AM
hauss's Avatar
Thank you, at least now I understand,that msd manual was very helpful.I kind of figured in my case rotor phasing was much about nothing but was not sure thanks again for the help.
