-   -   Sky hook? (http://www.clubcobra.com/forums/all-cobra-talk/143419-sky-hook.html)
my427cobra 03-28-2020 08:57 AM
Sky hook?
Sky hook?
So we all in these strange times may have a few extra minutes to work on our projects and/or ponder our navels.
I have always read with great interest all the posts talking about lifts: scissor lifts, two post lifts, four post lifts etc.
They all have their pros and cons including height, posts in the way, floor recesses for the scissor lifts, accessibility under the car etc etc etc.
So after my second irish coffee this morning, I had a eureka moment. We need a sky hook!
I’m certifiably nuts. Or drunk. Right?
Well maybe not. I got to thinking about all the cool ways I’ve seen cars lifted. And stored.
My first thought was the method race cars are loaded into the back of race car transporters. You’ve seen them. Flat decks that move the car up with cables and motorized screw jack principles. Think of that attached to the side wall or rear wall of your garage.
And if you’ve ever seen Denbeste’s wall of Cobras mounted on industrial cantilivered racking arms.
Think of pivoting or removable/ latch in place cantilevered arms attached to your garage side wall or end wall to support your car in the air.
So maybe cantilevered rack arms on a vertical motorized screw jack mounted to the side wall of the garage.
Yeah yeah, I know. Most residential garage wall structures aren’t built for that. That can be strengthened.
One more irish coffee and I’ll have this figured out.
Or I’ll be passed out.
Greg
t walgamuth 03-28-2020 05:52 PM
send pics when done please.;)
my427cobra 03-28-2020 06:37 PM
Way beyond my capabilities. Just conceptualizing.
But then I didn't think I could scratch build an IRS.
Greg
razerwire 03-28-2020 06:44 PM
When customer is a car guy I always try to talk
them into adding load points to the trusses. Does not cost that much and they can pick where they want to put pickup points. Nice to be able to pick up whole car and hang, works good for pulling engines or boats off trailer. Guy doing shop soon and I added point load of 1000 lbs every 10 feet 6 foot from back wall so he can put hanging shelf across back wall whole length, going to put dirt bikes, pedal cars quads ect on it.
Jim Vander Wal 03-28-2020 08:41 PM
When I had my chassis in the shop for frame work we suspended it by the rollcage with 10 ton crane. Sure does make things easy. N/S/E/W/U/D electric controls will spoil you in a heartbeat.
Jim
t walgamuth 03-28-2020 08:43 PM
I thought I was clever mounting an angle iron and lagging to the bottom so I can pull motors.....you guys are way ahead of me!
my427cobra 03-29-2020 07:51 AM
Ok guys. Now we're cooking with gas.
I'm thinking some glue lam beams added vertically along the inside wall of my garage to keep the wall from oil canning and a couple of glue lam beams along the ceiling (attached to the trusses above) to distribute the horizontal and vertical loads.
Mount the race car transporter load deck mechanism (TBD) to the wall to raise the car and the cantilevered racking arms mounted to the wall ( a la Denbeste) to support the car up in the air once it's raised into position.
Obviously still conceptual. I'll have to call in a few favors from engineer/architect friends.
Greg
Jaydee 03-29-2020 04:14 PM
As scary as it looks , a 1post hoist is probably the least intrusive. Put the post near a wall and raise it when not needed out of the way. I've seen 2 at a house to store 4 cars in 2 spots. JD
my427cobra 03-30-2020 10:37 AM
1 Attachment(s)
Yeah. I'm liking the concept of a one post lift. Saw these one post lifts on the net (Northern Tool) called a Tuxedo lift - 2000 lb with 58 inches of lift.
Could use two (4000 lb cap) on a side wall (one for front of the car, one for rear) and replace the lift deck with a longer cantilevered storage shelf beam (like Denbeste wall of Cobras) to go under the frame of the Cobra
Just thinkin.
Greg
my427cobra 03-30-2020 10:44 AM
And yes, if I was to do two of them, I would tie the two together at the top and tie them to the wall for stability.
See them on the net for sale at $1400 each ($1800 list). Wonder if the company would discount them further if they eliminated the deck?
Greg
