Like Tree6Likes
Old 04-01-2020, 01:47 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Default Battery Tenders but which one?
I finally need a battery tender not a charger but tender. Been putting it off for years but the time has come. Not looking too cheap out on this so don't hold back. Recommendations would be greatly appreciated.
Wayne Rogers in Hideaway, Texas
Old 04-01-2020, 01:55 PM
jetblue69's Avatar
Cobra Make, Engine: ERA #816, 427 Side Oiler
Afternoon Wayne...
I have both the 021-123 (3/4A) and the 021-128 (1.25A) and they're about $30 and $50 respectively. I think they also have a waterproof one if you plug your car in outside (I doubt you leave it outside). I use the .75A on my Mustang and the 1.25A on the Cobra, they both work great! I like the 3/4A a tad better since it's more portable...
Old 04-01-2020, 01:56 PM
Cobra Make, Engine: ERA #720
I have the actual brand "battery tender" and its been great.
rodneym and RUFdriver like this.
Old 04-01-2020, 02:17 PM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
I second that I have been using one since 1986. Have only had to replace it once.
Old 04-01-2020, 02:50 PM
twobjshelbys's Avatar
Battery Tender Jr. Works great. Had one on my Ford GT for 8 years. Factory battery lasted 7 on the tender.
ront49 likes this.
CSX4005LA
Old 04-01-2020, 03:00 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
I use a small solar panel trickle charger placed in the garage window. Works very well. And, it won't break the bank
Old 04-01-2020, 03:34 PM
EM-0785's Avatar
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Battery Tender brand, really do like it. Can find model later if interested.
For access, if helpful...
Initially with battery & cutoff switch front and center behind bulkhead, attached with nuts, dropped capped lead through access hole in vinyl trunk panel into trunk. When connected, cord ran under gently set trunk lid with soft cloth.
Currently moved battery & cut-off to rear pass side of trunk. Created an access hole out beneath at rear and dropped/fastened the capped lead tight below trunk for anytime access without opening the trunk.
Brent
Alfa02 and ront49 like this.
Old 04-01-2020, 04:35 PM
Mike I's Avatar
Cobra Make, Engine: E-M Cobra - RCR GT40
You don't mention the type of battery installed in your car. If it's lead acid, then any of the units previously mentioned will do fine. If you have an AGM type battery, you'll need something like the BatteryMINDer Model 2012-AGM, which will cost a bit more.
Old 04-01-2020, 04:38 PM
ERA174's Avatar
Cobra Make, Engine: ERA 427, 482ci sideoiler
I have the CTEK US 7002 (Part no: 56-353) and Battery Tender 10 watt Solar, both work well for me and can be hooked up for long periods. I use the solar panel in my spare daily driver, which is left outside, I've tried the 2 watt solar panels and they don't have enough capacity for my vehicles. The CTEK is used on my garaged vehicles when left for extended storage or to recarge a neglected battery.
https://mechanicbase.com/reviews/bes...tery-chargers/
https://earthtechling.com/solar-car-battery-chargers/
https://www.batterytender.com/10-Wat...-in-Controller
Old 04-01-2020, 04:47 PM
legenmetals's Avatar
I have used Battery tender and C-Tek. I only buy C-Tek now.
Old 04-02-2020, 07:28 AM
Battery Tender Plus is compatible with AGM and gel.
Old 04-02-2020, 08:55 AM
jetblue69's Avatar
Yeah sorry, I should have mentioned that those were actual "Battery Tender" part numbers and they'll work with any style battery!
Old 04-02-2020, 12:14 PM
Mike I's Avatar
I just reviewed the specs and description of the BT+, it does not mention AGM compatibility, and the reviews on Amazon are atrocious.
Old 04-02-2020, 07:29 PM
wrogers55's Avatar
OP, Thanks guys. Really appreciate this site and the immediate help, as always. I have ordered the CTEK (56-353) MULTI US 7002 and hope it's more than I need. Hard to believe there are so many choices and features (which will probably never be used) in the tiny world of battery tenders! ALL responses much appreciated. Great group of guy, as always.
legenmetals likes this.
Old 04-03-2020, 09:26 AM
jetblue69's Avatar
Well, i have AGM batteries in all my vehicles and I've had the small charger almost 10 years and the 1.25A version 5 years now with ZERO issues! I don't use the 1.25A all the time but the .75A is plugged in 24/7... I'd take the validity of an Amazon review with a grain of salt! Look, I don't want to turn this into a pissing contest but I actually own them AND use them. Just my honest 2 cents but everyone is entitled to their own opinion.
Old 04-03-2020, 10:00 AM
Cobra Make, Engine: ERA 427sc
I've been using BLACK+DECKER BM3B and it's been hassle free.
Old 04-03-2020, 10:58 AM
Almost all of them are made by CTEK or Battery Tender. I have a Interstate Battery that is a rebranded BT.
CSX4005LA
Old 04-03-2020, 11:17 AM
Direct cut and paste from their product
description within "Additional Information" :
"Perfect for all lead-acid, flooded or sealed maintenance free batteries (AGM and gel cell)."
https://www.batterytender.com/Battery-TenderR-Plus
Have 2 and used them for years without issue.
I use the 24v version BatteryMinder on
aircraft.
Old 04-03-2020, 05:57 PM
FUNFER2's Avatar
Really ?, please give us details ?
Is it water proof ?
Kevin
Old 04-03-2020, 06:40 PM
Is it water proof ?
Yes, especially if you put a 500w lamp right in front of the solar cell.
