Like Tree4Likes
  • 2 Post By 1Gooddeal
  • 1 Post By hi-tech cobra
Old 05-06-2020, 09:06 AM
Registered User
Cobra Make, Engine: Arizona 1997 Hi Tech
Default Help with Hi-Tech Motorsport 1997 from AZ
Trying to identify front and rear brakes, I'm working on a cobra that was built in 97 from high-tech in Arizona I'm familiar with some of the history of the builder, I'm looking for information for what applicat of wilwood front and rear brakes, it has an independent 9-inch rear and I do not know what the axle housings are for the rear and the spindles for the front to order the brakes I do not have calipers or rotors and they are knock-off hubs on the spindles, anybody have any information identifying the rear and front suspension so I can order the brakes wilwood I've been on the phone with them and we're trying to sort it out but it's a little bit of a guessing game because we didn't build the suspension and we don't know what application of the parts that are needed.
Any help greatly appreciated thank you.
1985 CCX and hi-tech cobra like this.
Old 05-06-2020, 04:13 PM
Cobra Make, Engine: SPF 1233-396C.I. Windsor
Wilwood Superlite calipers have a 3 1/2" bolt spacing for the caliper mounts. Dynalites are either 5" or 5 1/2" - sorry, I can't remember.. Looks like a typical 8 bolt rotor (8 bolts on a 7" bolt circle). Rotor diameter will be 11.75" or 12.19" diameter. You may have to mock something up to determine rotor width and diameter. PM me if you get stuck, good luck.
Mike Beamish / Northern Racing Products Superformance service & installation.
Old 05-07-2020, 09:27 AM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Always good to meet a fellow Hi-Tech brother. Let me know if I can help.
1Gooddeal likes this.
Old 05-07-2020, 09:29 AM
http://www.clubcobra.com/photopost/d.../DSC_0005b.jpg
Old 05-07-2020, 11:00 AM
Sawdust's Avatar
Could you take a picture of the pads and provide exact measurements to Wilwood in hopes they can match the pads?
Old 05-07-2020, 04:32 PM
Picture looks like Superlites- rotor width appears to be 1.250. Better question is anyone have pics of the rears? Not uncommon to run a .810 wide rotor in the rear. Rear does a small percentage of total braking so we use calipers with smaller pistons. Fronts should be staggered bore -1.875 & 1.750 piston. Rears calipers will be sold to specific rotor width and usually have 1.375 or 1.250" pistons. These are 4 piston calipers.
Old 05-20-2020, 12:28 PM
I tried sending pics. Having problems PM'ing you. PM me your email and I'll send.
