| 29 |
26Likes
02-06-2021, 06:29 AM
IN
Originally Posted by Morris
Just so you guys know.....the drivers weight goes on the LF, LR & RR
None of the drivers weight goes on the RF......so putting a battery on the passenger side ...ias long as you position the battery in the passenger side of the vehicle it will help balance the vehicle.
What is meant please by "goes on the RF"?
02-06-2021, 06:34 AM
Apparently, he sits on the rear tire.
02-06-2021, 06:50 AM
Abnormal CC Member
I think RR is rail road, GLWTA is good luck with the auction and RF is right front.
02-06-2021, 07:00 AM
I'd either never noticed or perhaps never seen a Cobra with those strut rods on top of the foot boxes? Obviously my ed-u-ka-shun is lacking. Were they standard or is this a one-off?
Karlos
02-06-2021, 08:07 AM
IN
Does it mean the weight is supposed to go there or does it mean it just does?
02-06-2021, 10:08 AM
IL
You guy’s are to funny....
Morris
02-06-2021, 10:46 AM
IN
I guess my confusion is irrelevant.
02-06-2021, 12:04 PM
Intuitively, you would think that if you place a ten pound weight in the driver's seat that the distribution of that weight might be three pounds each on the driver's side front and rear tires and two pounds each on the passenger side tires. But noooooooo, as you can see from my post above giving exact numbers, even when you plop almost two hundred pounds in the driver's seat, only one pound goes to the opposite side front wheel. I corner weight my car, and measure it both with me in and out of the car. It would be stupid to place a weight in your car, like a battery, without knowing what your distribution is before you choose where to place it. You might be making a small problem bigger by placing it in the wrong spot. Plus it will make getting the cross weight at 50%, and maintaining a nice stance, all the more harder.
But, to be honest with you, if you're not driving car ridiculously hard to begin with, it probably doesn't matter anyway.
02-06-2021, 05:15 PM
SA
Originally Posted by patrickt
...It would be stupid to place a weight in your car, like a battery, without knowing what your distribution is before you choose where to place it....
I understand what you're saying Patrick, however, my engine and transmission are yet to be fitted.... but I have to decide on a location for my battery now, using commonsense, so it's going in the trunk on the passenger side.
On their website, ERA state in their FAQs for the 427 that "Our standard car mounts the battery on top of the passenger's footbox, in approximately the same place as an original street car. Optionally, you can move the battery back into the trunk for more rear weight bias." By your reasoning, are they throwing caution to the wind, and saying "you choose"?
Cheers!
Glen
02-06-2021, 05:45 PM
No, they'll put it in the back if you want. On a 427 car, with an iron block, aluminum heads, aluminum intake, and few other aluminum parts, it's better to have the battery up front. Even with my battery up front, I'm 48% weight up front and 52% weight on the rear, with me in the car.
02-06-2021, 06:04 PM
IL
Having your battery in the trunk on either side is a dangerous situation because there is no protection for the battery especially next to the fuel container.....a simple accident could cause a major disaster.
And it doesn’t matter about your motor & transmission being mounted cause like Patrick said & I said on a US car....driver on the left side....the drivers weight goes on the Left Front, Left Rear, & Right Rear.....for those that don’t understand me....the Right Front will not get any significant weight......
Now placement of your battery is a weight you can move around to get balance where you want or need it....more to the rear will help rear weight but it needs to be encapsulated to prevent accidental damage.....in the passenger compartment it is protected by the cage or roll bar and side bar structure....which is much safer...
Down under where you are just reverse everything I said.....but more importantly mount the battery in a battery box for protection, and the main disconnect has to be reachable by someone outside of the car....and marked with a decal......just saying....
Morris
02-07-2021, 03:50 AM
SA
Hi Morris. Thanks for the comments.
I understand what you’re saying, and yes, ideally, I would mount the battery in an encapsulated box in my trunk. That is what I was initially considering…. but had to reject the idea because of the unrealistic intrusion in the available trunk space.
As I see it, the environment under the hood is somewhat challenging anyway for a battery, with extreme heat and the presence of a high pressure fuel system.
In the trunk, there’s an absence of high temperatures. Yes, there’s fuel, but not under pressure. Both trunk and under hood areas are at risk in collision conditions.
Glen
02-07-2021, 03:54 AM
Most of us, with non-original-style kits don't expose the tank in the trunk. It's behind sealed panels that separate it away from anything dangerous. The same way that almost all production cars do, including the Shelby 427 street model.
02-07-2021, 05:28 AM
Originally Posted by xb-60
As I see it, the environment under the hood is somewhat challenging anyway for a battery, with extreme heat and the presence of a high pressure fuel system. In the trunk, there’s an absence of high temperatures.
Mounted in the front under the fender wall is not as bad as you think. I put in a fresh battery last spring and, on ERA cars, you come in from the wheel well. Note the battery "box" and heat shielding, along with the ventilation mesh. The heat is not as bad as you think. Now, I don't have a high pressure fuel system. On a good day, it's 6psi at best. So I'm not sure what that concern is. If you get hit hard enough up front to rupture your fuel lines you're probably a goner anyway -- even if you left the battery back on the garage floor.
02-07-2021, 10:45 AM
Tx
Cobra Make, Engine: UCC GT 427
Here’s mine, enclosed battery box right rear, the fuel cell protected in it’s own metal enclosure.
02-07-2021, 11:07 AM
And why was that location chosen?
02-07-2021, 03:05 PM
Here’s where mine resides.
02-07-2021, 05:25 PM
SA
I'm thinking of leaving the battery out ....and the engine and trans. out as well ....
Cheers!
Fred Flintstone
02-07-2021, 06:05 PM
Cheers!
Fred Flintstone
That will definitely make it easier to corner weight it.
02-07-2021, 06:28 PM
Well, you might as well do it right. There's no point putting it in the boot if you've already got a weight percentage back there greater than 50% -- even if you think it's easier to do it that way. That's kind of like the guy that loses a bolt out in the driveway one night but searches for it in the garage because the light is better inside.
