Old 03-07-2021, 06:10 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Default Gauge Temperatures/Pressures
Just finishing up working on my dash switch and instrument labels project.
I have now acquired the proper red and green adhesive material to add as visual markers on the minor instruments and was looking for suggestions for the temperature splits for good/warning visual markers values.
Looking at the reference photo I have of the dash on CSX2002 (Below) the green/red split markers used, I note the following.
Water Temp looks like 212 degrees F.
Oil temp looks like 115 degree C. (Oil pan temp or oil filter sensor location?)
Oil pressure looks like 25lbs./in2
These look to be standard numbers?
Blas
SPFWiringDiagrams@Comcast.net
Old 03-09-2021, 07:51 AM
Blas,
Are you asking what the photo seems to indicate? Or what semi "normal" readings should be?
Call if you wish. I like the tape.
Jim VW
Old 03-09-2021, 10:46 AM
Blas's Avatar
Well fuel pressure could vary by cars setup.... Weber’s, EFI, etc. and. Oil temp by location of sensor, pan or filter. Oil pressure obviously hot/cold oil, oil weight, bearing clearances, water temp by thermostat/fans.
Just looking for others opinions. Perhaps best determined on a car by car basis?
I’ve had interest in the switch labels, was going to include in instructions.
Blas
Old 03-11-2021, 07:31 PM
Danr55's Avatar
Looks completely different from mine. My oil pressure runs about 52 psi under load and idles around 28-32 psi. Oil Temp usually runs in the 185 degrees F as does the coolant.( Im running a 180 degree thermostat.)
Dan in Arizona
CCX3209
Old 03-12-2021, 06:20 AM
Blas's Avatar
I believe the split between green/red on the tags identify the safe/danger temperatures. Where is your oil temp sensor located. Coolant temp varied with thermostat.
Blas
Old 03-12-2021, 07:01 AM
Blas,
I think there are good or "normal" ranges but each engine will be different. The radiator, oil cooling, oil lines/filtration, induction/fuel pump all change readings. Use, installation, ambient will all change what "normal" may be.
Max or min readings are more based on the engineering / technical designs of the engine and components.
Too cold can be almost as bad as too hot. I'd be inclined to show both sides of "normal".
But then I may not be the best person to ask about "normal".
