Like Tree1Likes
  • 1 Post By Gaz64
Old 04-12-2021, 05:34 PM
Default Hydro Lifter Noise
So ive read elsewhere, hydraulic lifters in pedestrian grade passenger cars are quiet and maintenance free...in a performance scenario they are neither.
So how noisy should they be, and at what point should they be ‘maintained’?
I have a hydo cammed 600hp windsor with a builders ‘secret’ cam...
Superformance 1764
Built 427W
Aiken SC USA
Old 04-12-2021, 07:25 PM
FredG's Avatar
Not sure what you mean by noisy but I can tell you that the hydraulic lifters in my 550 HP Roush engine don't make a sound.....zero.....not a peep out of them.
Old 04-12-2021, 09:34 PM
scootter's Avatar
Mine don't make noise in my 514 either.
Old 04-13-2021, 03:12 AM
Gaz64's Avatar
Any hydraulic camshaft, (flat tappet or roller), is designed to run with lifter preload, (after zero lash).
The camshaft base circle is ground differently than a solid camshaft.
Some guys might run their hydraulic preload as close to zero, as a safety margin against lifter pump-up. This only really occurs if the engine valve floats where insufficient valve spring pressure is used.
If you have adjustable valve train, and you want to run at just under zero lash, (eg: 1/8 turn past zero), then a periodic check doesn't hurt.
Otherwise, a correctly adjusted preload of 1/2 to 3/4 turn should be QUIET while the engine is running.
Some lifters are designed to be noisy regardless of adjustment. Rhoad lifters are the best example. Crane Hi-intensity are less noisy. The bleed off is designed to tame a little of the camshaft away at low speed, and give a smoother running engine when a wild cam is fitted. A little old school.
I have seen hydraulic cams fitted with hydraulic lifters that are converted to solid lifters. Those cams are NOISY, and have limited life.
Tommy likes this.
Old 04-13-2021, 06:05 AM
The biggest contributor to the noise is the cam lobe shape. A lifter in and of itself is not noisy, but if you have a quick cam lobe that is shocking the valves open and slamming them shut will not be quiet.
Most hydraulic rollers will have a bit of a sewing machine sound and it will go up from there to downright annoying.
