Old 05-12-2021, 08:37 PM
Default Looking for help with Older Triumph
I have a replica that used a 62-76 Triumph steering column. My current problem is Ii have the steering wheel removed exposing the upper shaft and need help describing the threaded end. I measured the threaded end OD with a Vernier caliper. It comes out at 13.08 MM or .5028" and my metric thread pitch gauge matched at .90 Can anyone clear it up for me. ?
Mike H
Old 05-12-2021, 11:15 PM
xb-60's Avatar
Mike,
I've checked in my trusty old Zeus booklet. 13.08mm is 0.515", so your thread is not a standard metric thread, and if we look at Imperial threads, 0.515" (or your quoted 0.5028"), there are no matching threads.
Closest I could find is 1/2" UNF ....OD is 0.5" and pitch is 0.050" (1.27mm), so no cigar.
1/4" BSP has an OD of 0.518" and pitch of 0.0526" (1.34mm), so still no good to you.
There are no standard metric threads that are even close. Standard metric OD's in your required range are M12 and M14 with standard pitches of 1.75mm and 2.00mm respectively.
Good luck!
Glen
Old 05-13-2021, 05:51 AM
MOTORHEAD's Avatar
whitworth ?
"When Injustice becomes Law,
Old 05-13-2021, 06:16 AM
Whitworth or possibly proprietary thread.
FYI, metric thread is rare in British cars before the '90s.
All the Triumph Spitfire column threads (mid-70s) that I have are .562" diameter.
Old 05-13-2021, 07:07 AM
Austin_Snake's Avatar
Cobra Make, Engine: Exact 427 Carbon Car
All Triumphs used the same nut from the 50's til they closed down. Should be a 9/16-27.
If you need a shaft or nut go to Mossmotors.com
Old 05-13-2021, 10:18 PM
My column and steering wheel is exactly like the picture 62-76 Triumph Spitfire. Moss motors still has the nut but what I want is be able to describe the threads on a drawing. What is the type and so on. What do I call it?
Mike H
Old 05-14-2021, 01:12 AM
xb-60's Avatar
Originally Posted by MOTORHEAD View Post
whitworth ?
1/2" BSW (ie Whitworth) pitch is way too large at 0.0833" or 2.12mm, so I didn't even mention it, and 1/2"BSF pitch is 0.0625" or 1.59mm
Old 05-14-2021, 07:20 AM
Pretty sure its 9/16-27 UNS. I can look in my Triumph Shop Manuals this weekend and verify the thread. They are usually more detailed than the part resellers. In the meantime check the Triumph forums.
Making a new steering column?
Richard
Old 05-14-2021, 04:16 PM
OH crap, I just put away my tap and die sets. I usually do not do put away very well. I found on the computer, a "BSC" (British Standard Cycle) that shows a 9/16" (0.5625" x 26 TPI) I'm still looking for a name I can really trust to list on this mechanical drawing. when I had the thread pitch gauges out my fractional tap and die set 27 and 28 TPI were awfully close matches. I should have gotten more light and a piece of white paper as a contrasting back ground. Other than the Wentworth I have never heard of these thread systems before. Talk about living in a BOX.
Mike H
Old 05-14-2021, 04:20 PM
If it were me, I'd post my question on the Triumph Club's website... in the U.K. https://www.clubtriumph.co.uk/
Old 05-14-2021, 04:39 PM
I did look up UNS and they do show a 9/16"x 27 TPI. No experience with UNS . but it seems to fit my parameters. McMaster showed UNS 9/16" x 16-20-27- and 32 tpi I never heard of UNS before. but it seems to exist. All this is to complete a mechanical drawing I asked my Son to create for me while my steering shaft is exposed with the steering wheel removed. I want to have accurate information.
Mike H
