Like Tree13Likes
Old 03-05-2022, 07:41 AM
Cobra Make, Engine: Kirkham 289 slabside, 302 SBF
Default knockoff spinner tool
I just tried the knock off spinner tool made by Sarto Rocheleau in CA- this is machined aluminum alloy item which fits over the 3-eared spinners on my Kirkham Cobra and Safir GT40. Comes with everything needed included a wheel chock. This is the best and most effective tool for this that I've ever seen or used.
I have no financial stake in this, and I did not know the manufacturer until I search on line for this, but this is a beautifully made tool which will do its job admirably AND protect your knockoff spinners at the same time. Anyone with a Cobra and knockoff spinner wheels should own one. I have also emailed KMS, who built my car, about this.
We also own an old Jaguar, a Series 1 E-type, and I purchased the tool that he makes for that car as well. Fits equally well, and just as well made.
Old 03-05-2022, 12:01 PM
look on line not sure who sells them but they make a puller i have one works great
Old 03-05-2022, 12:45 PM
DanEC's Avatar
A link for those interested.
https://knockoffspinnertool.com/
ERA 782 Running
Old 03-05-2022, 02:52 PM
Senile Club Cobra Member
Any tool that does not have a "shock" will not properly tighten a knock-off. A wrench will not do that.
Ozzie Goat likes this.
rick@autoventureusa.net
Old 03-05-2022, 03:36 PM
Unless you are using a torque wrench to 450# ft lbs....on a center-lok nut...
jmarsey and eschaider like this.
Morris
Old 03-05-2022, 03:42 PM
OK, who wants to revisit the "I Can Remove My Spinners With One Finger" thread?
Old 03-05-2022, 05:22 PM
twobjshelbys's Avatar
Seriously, all you need is an American Hammer lead mallet. Getting it off the first time might be a chore, but bang each ear in rotation until it comes loose, and it will, then be sure to use anti-sieze on it before reassembing (be stingy, you don't need much and trust me if it oozes out it's a mess). Tighten it by hitting on each ear until it "sings" - you'll notice a tone change in the sound when its tight and they all sound the same. Then you'll have an easy off with the mallet after that.
CSX4005LA
Old 03-05-2022, 05:27 PM
C'mon, how many of us can really swing that six pound lead hammer 25 times when we're pushing 80? Gimmee an air gun any day.
Old 03-05-2022, 07:25 PM
look for spinner911 works great
Old 04-07-2024, 06:45 PM
Cobra Make, Engine: ERA 377 - 428SCJ
I have tried every thing including propane, lead hammer and 10 foot lever. I have a large specially made fixture that slides into the hub and over the 'wings' with steel arms to whack with the hammer or slide the lever over. Nothing. I have oxy-acetylene but worried about over heating the aluminum knockoff. Any suggestions welcome.
Terry
Encino CA
ERA 377
428SCJ
Old 04-07-2024, 06:51 PM
But for the fact that it's an ERA, I would suspect the hubs are on the wrong sides of the car. Have the wheels ever been off the hubs?
Blue66 likes this.
Old 04-08-2024, 04:41 PM
DanEC's Avatar
You might see if you can find one of these. If the photo comes through.
https://share.icloud.com/photos/0987...3k-9bQ8AkqOwSA
ERA 782 Running
Old 04-08-2024, 06:05 PM
cycleguy55's Avatar
Here's a link to videos showing the tool in use: https://performanceunlimited.com/cob...911videos.html
CompFi likes this.
Brian
Old 04-12-2024, 02:15 PM
Default Knockoff spinner tool
Thanks to all. If I can't get the spinners off tomorrow, will probably spring for the 9-1-1 tool
CompFi likes this.
Terry
Encino CA
ERA 377
428SCJ
Old 04-13-2024, 06:14 AM
DanEC's Avatar
You have probably done this already but it couldn’t hurt to saturate it with the best creeping, penetrating oil you can find. And I assume you do have the car sitting on the ground with weight on the suspension? It also might help to roll the car and work on all 3 ears of the spinner with a mother thumper 6 lb lead hammer, rather than concentrate on one ear.
Blue66 likes this.
ERA 782 Running
Old 04-15-2024, 05:07 PM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
Terry, try this. It's expensive, but probably your best bet. I borrowed one from a buddy and worked great.
Best,
Matt
Hurricane Motorsports #1053; 427w
Old 04-15-2024, 05:10 PM
MFE III's Avatar
I borrowed this from a buddy and it got my stuck spinners off.
This tool was also posted earlier in this thread
sgianino and Kthulu like this.
Old 04-16-2024, 07:02 AM
I have one here I used .. PM if interested
Dan
427 CSX 3000/4000 and Shelbys.
All gone ! Was a Hell of a run
Now ... The dogs car
Mercedes E63S station wagon. 603hp
Old 04-16-2024, 12:10 PM
Kthulu's Avatar
I saw this thread several days ago and finally figured it was time to pull the trigger on an alternative to whacking my expensive car with a hammer. I picked up the set from https://knockoffspinnertool.com/ and am really impressed with how nicely made it is! I'll be using it from the first time in a couple of weeks when it's time for Spring cleaning.
Thanks to everyone for sharing their knowledge on this topic! Made it a lot easier to spend the money when I knew I was getting something good!
Old 04-16-2024, 01:58 PM
WHen using the lead hammer it is ESSENTIAL that you tap each ear in succession all the way around and repeat in that pattern. Doing one ear only will likely get you a broken ear.
CSX4005LA
