Like Tree1Likes
  • 1 Post By Luce
Old 11-14-2022, 01:02 AM
Registered User
Default 302 & 351W headers
Beautiful girl's ***** throbs and cums - https://sexcam.cafe
Public orgasm test - https://camgirls.place
Sharing my Boyfriendwith my lovly Girlfriend - https://livesex.work
Old 11-14-2022, 02:40 PM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
That's more dependent on the heads than the block.
jolsen42 likes this.
Old 11-15-2022, 04:56 AM
Cobra Make, Engine: built the molds and body composite construction
Default 302& 351W headers
These headers are not interchangeable regardless of the port description for a Cobra because of the differences in the deck height of the two blocks and the with of the the blocks without modification.
Bill K
Old 11-15-2022, 05:40 AM
They could be the same header depending on the application. Its more of a chassis thing. 351 headers would hang a little lower if installed on a 302 If they would fit the chassis. Same goes for 302 headers on a 351. They will bolt on but may interfere with the floor pan or shock towers ect. In the case of a Cobra, they probably would not exit the body correctly.
Old 11-15-2022, 08:27 AM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
You can use headers that were made for a 289/302 engine on a 289/302 engine with 351W cylinder heads.
