Like Tree37Likes
Old 10-01-2023, 09:17 AM
twobjshelbys's Avatar
Originally Posted by eschaider View Post
This is the world's largest open air sanitarium, Brian. What else would you expect.
And the inmates are in charge.
CSX4005LA
Old 10-01-2023, 02:42 PM
eschaider's Avatar
Yes, they are, Tony!
Old 10-02-2023, 10:37 AM
hauss's Avatar
save your money just change our oil often, with good quality, clean oil .No need to get it anal- ized like some people.
Old 10-02-2023, 12:07 PM
Well I'm curious, if you had a small internal coolant leak in to your oil would you want to know that? Or if bearing material, or maybe a cam lobe, was starting to appear?
Old 10-02-2023, 01:06 PM
eschaider's Avatar
This is clearly a charter member of the 'don't worry, be happy' crowd, Patrick.
The level of knowledge, detail, scrutiny, and proactivity you are suggesting is simply not relevant or wanted until post-failure. Then, of course, it is Katy bar the doors because all manner of foolish, obscure testing and procedure is embraced like a long-lost family member in order to explain the now "unexpected" massive mechanical failure the individual is confronted with.
Old 10-02-2023, 01:09 PM
Well, that said, I'll just STFU on the subject.
Old 10-02-2023, 01:30 PM
eschaider's Avatar
I'm not so sure it is a STFU juncture as much as it is an ignore the commentary from the cheap seats sort of event.
Old 10-02-2023, 01:55 PM
The results are the same: Engine (maybe) needs to be rebuilt, some time. The only thing that changes is whether you do it proactively or reactively. Catching some of them early may avoid collateral damage and that can be worthwhile. I'd say if you had an original period correct FE with all time correct pieces maybe I'd worry. But if I had a new built modern block with modern internals I'd treat it more like a new engine in a daily driver.
CSX4005LA
Old 10-02-2023, 04:47 PM
sunman's Avatar
Antifreeze is fluorescent.
Check oil with black light for coolant leak.
I’ve got a magnetic plug and hard drive magnets on the bottom of my pans.
Chief engineer of Nissan GT-R program recommends 4000 miles.
Chaney Shores Studio
Old 10-03-2023, 06:08 AM
undy's Avatar
Or... look for the "milk shake" in the valve covers.
Blue66 and sunman like this.
Too many toys?? never!
Old 10-04-2023, 01:56 PM
1985 CCX's Avatar
These cars are so low, how does one get under it to change the oil??
PDUB likes this.
Old 10-04-2023, 04:10 PM
lift or jack stands.
CSX4005LA
  #33 (permalink)
Old 10-04-2023, 06:00 PM
Cobra Make, Engine: era#671 Keith Craft Motor
I usually stop eating for 3 months to flatten out a bit so i can sneak under enough to reach the pan drain screw......My BMI gets to about 12
  #34 (permalink)
Old 01-03-2024, 10:37 PM
Gaz64's Avatar
My last oil change was four years ago. I like to get yearly UOAs by Blackstone Labs and the one below came today. I look, of course, for wear particles, but I also look for anything that's in the oil that shouldn't be in the oil, like water, antifreeze and gas. That, along with the flash point, viscosity and TBN tell you whether or not you have a problem and whether you need to change your oil or not. The "I change my oil yearly for peace of mind" mindset is for idiots. Not to mention that SAE has papers supporting the theory that changing your oil too often actually increases engine wear. Zinc/Phos numbers can be misleading though because you don't know if that is "used" or not. But unless you have a solid flat tappet you don't really care about that as much as I do.
Not trying to hijack you Patrick.
I'm trying to work out some pattern why some threads are wider than my screen.
Clearly a Club Cobra website issue, since I don't get this anywhere else.
  #35 (permalink)
Old 01-04-2024, 12:13 AM
Exclamation Well...
some posted photos are wider than the normal format for the site software and the software expands the width to accommodate them... and makes it difficult/frustrating to view.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
  #36 (permalink)
Old 01-04-2024, 03:02 AM
This site does not scale images to the window but displays them at their full resolution and makes thexwindow bigger (with scroll bars). One image in a page causes the whole page to go wide. Some images are made thumbnails and don't cause this. Some get fully embedded and do. I try to post images less than or equal to 1024 on the long side. Helps for both display and upload time. I dont think 50mp images of an engine bay add much value
CSX4005LA
  #37 (permalink)
Old 01-04-2024, 05:39 AM
I resize my pics to 800 width 600 height before posting them here. Other sites do that on the fly for you, but not here. Participation on this has dropped off by 90% from what it was, mainly because the site uses software from the stone age that is limping along with a crutch and cane.
Tommy and eschaider like this.
  #38 (permalink)
Old 01-04-2024, 08:33 AM
DanEC's Avatar
I wonder where everyone has gone for “Cobra” companionship? I belong to another, small Cobra forum but it’s kind of a small group who for the most part are politically aligned and gives us collectively a place to vent and rage and talk pretty much about anything including Cobras. So it’s not necessarily a place for everyone although everyone is welcome. But it doesn’t tend to get too deep into Cobra-ism, and Cobra build projects. Just curious.
ERA 782 Running
  #39 (permalink)
Old 01-04-2024, 09:13 AM
Tommy's Avatar
I don't know where they go now. But I think the shift began about the time Superformance and Backdraft became the favored cars for people who wanted to own a Cobra without having to know how to build or maintain it. In the early days of this forum there was a lot of discussion about technical matters by people building or modifying cars in their own garages. Now days its seems more likely for people to discuss which brand has better resale value. I don't hear much about people taking their cars to the track either. I think the profile of the typical Cobra owner has changed and that is reflected in how and if they participate in this forum. . . . and of course the regular site outages don't help either.
FWIW: When I submitted this comment the system gave me an error message (seeming to invite me to submit it again). Knowing that's why we get so many duplicate posts, I simply closed out the page and reentered the site to see my post where it belonged. This has been going on for years and likely discouraged some less determined people from coming back.
eschaider, DanEC and nkb like this.
Tommy
Previously owned EM Cobra
  #40 (permalink)
Old 01-04-2024, 10:28 AM
And baling wire and bubble gum. And occasionally duct tape.
And it's building up to another failure. Lots of extremely long events - e.g., opening a topic, next page, etc. Posts are almost always ended with an error (the post happens, but people retry without looking which is why we see duplicates). Soon it will freeze up, go off the air for a few days, be on life support and get a cardio shock and come back again. Happens about every 3 or 4 months.
eschaider and nkb like this.
CSX4005LA
