16Likes
06-04-2024, 04:14 AM
UK
Cobra Make, Engine: Shell Valley Daytona, Ford 302
Hot starting problem.
Sorry if this is a bit of a numpty question but my Daytona fitted with a 302 and Edelbrock Thunder 1805 carb is difficult to start when it’s still hot. I think it’s due to fuel evaporation not heat soak on the starter. It will start eventually but after an embarrassing amount of churning. Is there a technique I can adopt to improve things like opening the throttle wide but don’t know the exact details?
06-04-2024, 06:50 AM
If you think fuel evaporation due to heat soak is the issue,
lifting the hood after shutdown helps. Of course in a Daytona
that's also a PITA.
Check that fuel lines are not making contact with the engine.
Insulate fuel lines near engine.
Install a heat shield kit around carb.
If all else fails you can also try...........
Using non-ethanol fuel mixed with unleaded racing gas.
Race gas has a lower RVP (Reid Vapor Pressure) rating
for the specific purpose of better starting characteristics
of heat soaked engines. Downside is you may need to
adjust/tune for it. Sunoco 260 GTX is non-oxygenated
unleaded 98 octane. 91 octane non-ethanol mixed
50/50 with 260 GTX is confirmed to work well for hot
starts and reduced vapor lock tendencies.
06-04-2024, 09:26 AM
Next time you park it hot... give it 15 minutes with the hood down and then take the air cleaner off and look at the top of the butterflies for puddled gas. Watch for drips of gas from the boosters. look for suspicious wet spots or brown stains on the outside of the carb at the downside (meaning the direction that a drip would go if it was running off your butterflies) especially on the butterfly shaft. Any of those will tip you that you have a percolation problem. If you see none of that, with your hand on the carb linkage give it a good "push to the floor" and watch for accelerator pump to see if it will squirt gas out in two nice strong streams. Those two tests will put you down the road to success. Personally, I'm betting on percolation.
06-04-2024, 11:45 AM
BC
1/4" heat gasket
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
06-04-2024, 11:46 AM
BC
1/4" heat gasket
06-05-2024, 05:23 AM
Open the throttle to about 1/3 initially.
If it struggles to start, at least you haven't flooded it worse.
While it is cranking, open the throttle wide.
As soon as it fires, back off and control the rpm as usual.
Add a heatsoak spacer or heatshield etc.
06-05-2024, 01:55 PM
SC
Originally Posted by HighPlainsDrifter
For all of my race cars, I prefer the Mr Gasket kit, part # 3710 , as it gives more options. You only need one heat shield, and two gaskets, and do not have to use the whole kit.
Dozens upon dozens of cars I've dealt with, and this fixes any carb percolation issues I've run across.
Bill S.
06-05-2024, 06:33 PM
NJ
fuel pump
do you have a electric fuel pump? You can put one in line with a check valve Turn it on to fill the bowls before starting … solved it for me
jom
06-06-2024, 05:48 AM
What Gaz64 posted.
06-06-2024, 08:05 AM
I had this problem and cured it with some silicone tubing over the fuel line as well as changing the line from copper to steel. Steel doesn't absorb heat like copper.
Here's a "before" pic:
Here's an "after" pic:
Here's the silicone tubing I used. It was 10mm ID and slid over the 3/8" fuel line. 3/8 ID silicone tubing would be too difficult to slide over the fuel line:
https://www.amazon.ca/gp/product/B073DXX9QB/
The steel line was just a piece of brake-line. Cut the flare off one end, cut to length, removed the fittings it came with, installed my own and the tubing, then re-flared the cut end.
Problem gone and has never come back.
06-06-2024, 08:10 AM
An Authoritative Quote...
"Copper interferes significantly in the gum content of gasoline, because it is a catalyst of radicalar oxidation reactions and it accelerates peroxidation. Therefore, this metal must be avoided in any metal alloy that comes into contact with gasoline in the feeding system of engines."
Source: https://www.researchgate.net/publica...otive_Gasoline
06-06-2024, 08:25 AM
Yes, I've heard that before. I used that copper line from when I first got the car on the road back in 1997 until I changed to steel line in 2018. I guess the reaction is slow.
06-06-2024, 11:19 AM
SK
jom
What saltshaker wrote.
Brian
06-06-2024, 05:53 PM
Here are two other suggestions that would probably work well if it is heat soak . I run a wood insulator under the carb that is readily available from Summit in various thicknesses . Seems to work better on my FE that the shield for some reason .
Another area that is generally overlooked is the fuel pump . It`s sitting right against the hot engine block and is lubricated by hot engine oil . I found a company …… Seals - It , who makes a fuel pump heat insulator gasket set that they came up with for Robert Yates Racing for their Windsor engines .
It consists of a special insulator gasket , insulated bolts and a hot oil shield that keeps the hot engine oil out of the pump . Since the fuel pump is lubricated with splash engine oil , it obviously needs some lube from somewhere . So , they installed a grease fitting in the pump body and pack it with grease .
I put that setup on my FE minus the seal gasket . Even though it`s an FE , the gasket fit fine with no leaks and only moved the pump out about 3/16” . No problems with overstroking the pump with that small a change ( I installed it , turned it over some , pulled the pump off and checked the ride pattern on the pump actuator arm ) . This kit is also available from Summit for around $50 to 60 US dollars .
Just a thought .
06-07-2024, 02:13 AM
UK
Thanks Patrick I will follow your tips next time I have it out. I should have added that once started it runs fine.
06-07-2024, 02:32 AM
UK
I think phenolic spacers do work but unfortunately there is very little space between the air cleaner and bonnet to increase the height of the carb.
06-07-2024, 02:39 AM
UK
jom
No I don’t. It’s mechanical.
06-07-2024, 02:41 AM
UK
Thanks John that’s a neat solution I wouldn’t have thought of. I’ll investigate my fuel lines.
06-08-2024, 02:19 PM
CC Member / Sponsor
UT
In addition to what others have recommended, look into a bypassing fuel pressure regulator. It works extremally in curing vapor lock.
06-09-2024, 05:33 AM
Cobra Make, Engine: built the molds and body composite construction
SOME PICTURES WOULD BE NICE TO SEE WHAT YOU ARE WORKING WITH. If you haven't gone to an air box you should consider it as it will drop your carb temp that it maybe enough to solve your problem. Look at the air box in my album.
BillK
